August 26, 2022, 03:43 |
Interpreting cyclic BC
Sreehari Perumanath
Rep Power: 4 |
Dear Foamers,
I am fairly new to OF and I'm using v6 to simulate a the channel395 case which has cyclic BC in x,z directions. After the simulation run, when I look at the results using "Point Data" in Paraview, I see that the patches where cyclic BCs are applied do not have identical field values. For example, the first point along x axis [say, on the left edge of the box at any given (y0,z0)] and the last point along the same axis [i.e. on the right edge of the box at the same (y0,z0)] do not have identical field values. Shouldn't they be identical? Am I doing something wrong in interpreting the results? Can someone please help me? Thanks in advance! S |
cyclic bc, interpolation, paraview |
Cyclic boundary condition in foam-extend 4.0 | rellumeister | OpenFOAM Pre-Processing | 2 | March 3, 2020 09:03 |
time step continuity error increases with time_SRFSimplefoam | mostafa kamal | OpenFOAM Running, Solving & CFD | 7 | October 2, 2019 03:00 |
LES in OF 3.0.1, no Output for nuSgs | Mirage | OpenFOAM Programming & Development | 1 | October 4, 2016 19:00 |
Possible createPatch/createBaffles bug? | simpomann | OpenFOAM Bugs | 2 | July 15, 2014 08:07 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 18:08 |
