Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Post Processing pressure difference with fieldValueDelta gives error
Old   July 15, 2022, 04:15
Default Post Processing pressure difference with fieldValueDelta gives error
Daniel
CFDanielGER is on a distinguished road
Hello everyone,
I want to calculate the pressure difference between the inlet and outlet of my domain with the following code:
      Druckdifferenz
        type                      fieldValueDelta;
        functionObjectLibs         ("libfieldFunctionObjects.so");
        enabled                   true;
        writeControl            timeStep;
        writeInterval            1;
        log                        true;
        writeFields                false;
        operation                subtract;
        region1
              type                    surfaceFieldValue;
              libs                    ("libfieldFunctionObjects.so");
              log                     false;
              writeFields             false;
              regionType              patch;
              name                    inlet;
              operation               areaAverage;
              fields                  ( total(p) );
              writeArea             true;
        region2
              log                     false;
              writeFields             false;
              regionType              patch;
              name                    outlet;
              writeArea             true;
I didn't put it in the controlDict file, more precisely I have a seperate file in the system directory with some other functions I am postprocessing. I call this file with the following code:
simpleFoam -postProcess -dict "system/PostProcess_Werte" -latestTime
For older versions the code works without problems but now it gives me the following error:
--> FOAM IOWarning :
Found [v1612] 'functionObjectLibs' entry instead of 'libs' in dictionary "functions.Druckdifferenz"
This keyword is 60 months old.
--> FOAM Warning :
Unknown function type fieldValueDelta
Is someone aware of this problem and knows what I have to change?
Many thanks for your help and best regards,
Daniel
CFDanielGER is offline   Reply With Quote
Old   July 18, 2022, 07:08
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Daniel,
They changed the name to multiFieldValue for version 2112.
The warning just means you can use libs instead of functionObjectLibs in the controlDict.
Best Regards,
Tom
tomf is offline   Reply With Quote
Old   July 18, 2022, 08:26
Daniel
Many thanks for your answer Tom. My complete code looks now like this:
|  \\    /   O peration     | Version:  v2112                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      functionObject;
functions
    pressureDropInletOutlet
        type            multiFieldValue;
        libs             (fieldFunctionObjects);
        operation       subtract;
        region1
            log             false;
            writeFields     false;
            regionType      patch;
            name            inlet;
            fields          (total(p));
        region2
            log             false;
            writeFields     false;
            regionType      patch;
            name            outlet;
            fields          (total(p));
But there is still an error:
--> FOAM FATAL IO ERROR: (openfoam-2112)
Entry 'type' not found in dictionary "functions.pressureDrop"
file: functions.pressureDrop at line 21 to 48.
    From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType::option, bool) const [with T = Foam::word]
    in file lnInclude/dictionaryTemplates.C at line 322.
FOAM exiting
Am I missing something?
Old   July 18, 2022, 08:36
Tom Fahner
It is a bit weird that is says functions.pressureDrop instead of functions.pressureDropInletOutlet, so maybe the issue is in the controlDict, or the naming of the file when you issue the command? Or it is because you have the call to the functions in there? I can only guess based on the information you share.
I Hope that some of these questions help you find your issue, I do not see any obvious syntax error in the example you provide.
Cheers,
Tom
Old   March 16, 2023, 13:20
s1291's Avatar
s1291 is on a distinguished road
Originally Posted by tomf View Post
Cheers,
Tom
This might be irrelevant to the error above but the multiFieldValue function object requires that the regions' dictionaries be included within "another" functions dictionary.
This is the syntax according to the documentation:
multiFieldValue1
    // Mandatory entries
    operation   average;
    // List of fieldValue function objects as dictionaries
    functions
        region1
            // Optional
            resultFields        (field1 field2);
        region2
            // Optional
        regionN
            // Optional
"When in doubt, use brute force." -- Ken Thompson
s1291 is offline   Reply With Quote
Old   March 17, 2023, 02:49
Daniel
Sorry for not updating this post. I got it working. I created a file called pressureDrop in the system directory and the code looks now like this:
        type            multiFieldValue; //fieldValueDelta; multiFieldValue;
        operation       subtract;
        functions
        region1
            log             false;
            writeFields     false;
            regionType      patch;
            name            inlet;
            fields          (total(p));
        region2
            log             false;
            writeFields     false;
            regionType      patch;
            name            outlet;
            fields          (total(p));
I call it in the controlDict file by:
#includeFunc pressureDrop
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
