May 16, 2022, 06:35 |
surfaceFieldValue post-processing
Akshay
Rep Power: 6 |
I am unable to create surface filed value post processing operating in controlDict. I have created the facezone from facesets at the required position inside my mesh domain, I want to take the area average of the alpha.gas phase at this region. I am getting an error. Someone please help, this is my thesis work and my work is getting delayed due to this and I am very near to the Deadline. I am using ESI OF version 8. Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name internalFaces; type faceSet; action new; source boxToFace; sourceInfo { box (0.9823 0.0965 0.457) (1.002 0.1403 0.528); } } { name internalfacepatch; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet internalFaces; cellSet internalCells; flip false; } } Code:
outlet_oxygen { type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; surfaceFormat none; regionType faceZone; name internalfacepatch; operation areaAverage; weightField alpha.oxygen; fields ( alpha.oxygen ); } Code:
Starting time loop surfaceFieldValue outlet_oxygen write: --> FOAM FATAL ERROR: surfaceFieldValue outlet_oxygen: faceZone(internalfacepatch): Unable to process internal faces for volume field alpha.oxygen From function Foam::tmp<Foam::Field<Type> > Foam::functionObjects::fieldValues::surfaceFieldValue::filterField(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, bool) const [with Type = double] in file fieldValues/surfaceFieldValue/surfaceFieldValueTemplates.C at line 416. FOAM aborting Generating stack trace... Backtrace: ZN10StackTraceC1Ev [0x626c1855+0x25] module: C:\PROGRA~1\BLUECF~1\ThirdParty-8\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll ZN4Foam5error10printStackERNS_7OstreamE [0x6c30ae5a+0x23a] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll ZN4Foam5error5abortEv [0x6c0c68b1+0x211] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll ZNK4Foam15functionObjects11fieldValues17surfaceFieldValue11filterFieldIdEENS_3tmpINS_5FieldIT_EEEERKNS_14GeometricFieldIS6_NS_12fvPatchFieldENS_7volMeshEEEb [0x922fb68+0x1d8] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libfieldFunctionObjects.dll ZNK4Foam15functionObjects11fieldValues17surfaceFieldValue14getFieldValuesIdEENS_3tmpINS_5FieldIT_EEEERKNS_4wordEbb [0x9231d7f+0x36f] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libfieldFunctionObjects.dll ZN4Foam15functionObjects11fieldValues17surfaceFieldValue5writeEv [0x903d1e6+0x166] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libfieldFunctionObjects.dll ZN4Foam15functionObjects11timeControl5writeEv [0x6c18a32d+0x2d] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll ZN4Foam18functionObjectList5startEv [0x6c180acf+0x8f] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll ZNK4Foam4Time3runEv [0x6c18ccfd+0x19d] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll (No symbol) [0x472123] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\bin\multiphaseEulerFoam.exe (No symbol) [0x4013c1] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\bin\multiphaseEulerFoam.exe (No symbol) [0x4014f6] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\bin\multiphaseEulerFoam.exe BaseThreadInitThunk [0x7ffbb2517034+0x14] module: C:\Windows\System32\KERNEL32.DLL RtlUserThreadStart [0x7ffbb32e2651+0x21] module: C:\Windows\SYSTEM32\ntdll.dll Regards Akshay |
May 16, 2022, 09:23 |
this solved the issue
#2 | |
Akshay
Rep Power: 6 |
HTML Code:
https://www.cfd-online.com/Forums/openfoam-post-processing/242807-how-extract-alpha-cell-data-area-within-domain.html#post828080 |
post processing, surfacefieldvalue, toposetdict, twophaseeulerfoam |
post processing for CEL expressions | Niru | CFX | 0 | May 10, 2013 13:13 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
CFD post processing techniques & streamlining | klk | Main CFD Forum | 0 | October 19, 2010 07:37 |
fluent for post processing | James | FLUENT | 0 | April 21, 2006 04:43 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
