Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Postprocessing using controldict functions does not work multiple regions
Old   March 6, 2022, 09:23
Unhappy Postprocessing using controldict functions does not work multiple regions
Richard Omega
rjomega is on a distinguished road
I am trying to do a fan heatsink simulation using openfoam (cyclicAMI MRF and chtMultiregionFoam) but I am having some trouble postprocessing the data to see if the volume and surface temperature stopped changing since residuals is not enough to see if the case has fully converged.
The case is working fine, it's just that whenever I try to add something in the functions part in controldict, it keeps on saying "request for objectRegistry region0... failed"
splitMeshRegions -cellZones -overwrite
separate fluid domain and AMI to different folders
mergeMeshes fluid AMI -overwrite (Combine fluid domain and AMI using fluid as master)
Return the merged mesh to the case folder and then deleting the fluid and AMI folders in constant and add the newly merged mesh as fluid
Why I did this? I am having some trouble setting cyclicAMI in separate regions
This problem seems to only occur because of my poor strategy of meshing outside of the case and just copy pasting the merged mesh into the original case folder. Is there any chance that I can use mergeMeshes to combine two regions? I have already done my researches to see if there are other people experiencing my situation and there seems to be some but they were not able to come up with any solution.
rjomega is offline   Reply With Quote
Old   March 6, 2022, 22:53
Richard Omega
I did not know that I also have to define the region in the residual postprocessing. My bad. Everything is working fine now.
chtmultiregionfoam, controldict, multiple regions, openfoam, postprocessing
Pipe Flow with Multiple Regions for Computer Cluster wcj1n18 STAR-CCM+ 4 July 8, 2021 06:41
chtMultiRegionFoam with multiple liquid regions tonnykz OpenFOAM Running, Solving & CFD 8 March 11, 2019 12:32
Merge multiple regions to use simpleFoam arnaud6 OpenFOAM Pre-Processing 6 June 24, 2015 03:48
porousSimpleFoam multiple soil regions sdp203 OpenFOAM Pre-Processing 1 August 19, 2014 20:42
How do size functions work in Gambit san FLUENT 0 February 22, 2006 08:05
