young4of
Rep Power: 4 ![]() |
Dear all,
I found that there is no post-processing utility timeActivatedFileUpdate in foam-extend-4.0 like in foam-extend-4.1. And I want to control the output in my case,so that a section of calculation can be output in a relatively small time step. Could I compile timeActivatedFileUpdate for foam-extend-4.0 by using the files in foam-extend-4.1? How can I compile it? If so, could you please tell me the specific process? Also, is there any other way to control the output? Thanks for reading and your reply. Young. |
controdict, foam ext 4.0, utlity |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
