February 15, 2022, 06:50 |
paraview question (dambreak4phase)
Rep Power: 4 |
hello, i am a beginner of openfoam !
when i studied dambreak4phase, i had a question.. there are four materials, air, water, oil, mercury in dambreak4phase case.. and i want to see the motion or flow of those materials simultaneously in one screen!! however, the option that i can view the flow of the material only allows me to see the motion of one of these materials mentioned above respectively.. (the option that i mentioned is "coloring". "coloring option" in "Display" only provides the single motion of the material respectively, not simulataneously.. for example, when i selected water, the water appears in screen. and then to want to see the flow of oil with water, so if i selected oil, and then water disappear in screen,, so i can only see the oil... i want to see the flow of water, oil, mercury simulatenously !! ) is there anyone to tell me solution about this? (actually i found one way to achieve this,, this is related "groupdataset" and "adjusting opacity", but this method is not efficient.. because i have to adjust opacity, it's difficult for me to see the material clearly after adjusting the opacity) |
October 10, 2024, 07:43 |
Wesley T.
Rep Power: 17 |
I realize it has been a long time since this was posted, and I have the same question.
A solution is shown starting at page 19 of this document: https://www.tfd.chalmers.se/~hani/ku...ssonReport.pdf The version of ParaFoam/ParaView in the link is older, the document is from 2010, and was run from OpenFOAM 1.7. I needed one more step: further down in the "Properties" tab is a section for "Colors" that needs to be set to "alphas". I am sure there is some more refining of the color scale that can make the phase much more clear, but this is at least a start. I hope this is helpful to others searching for guidance on how to show multiple phases at the same time. Wesley |
[OpenFOAM] Paraview client/server does not work with ParaView 5.0.1 | snak | ParaView | 0 | October 17, 2016 11:22 |
[General] Paraview Binary and OSPray plugin | Prapanchnair | ParaView | 0 | May 27, 2016 07:26 |
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam | MikeHersee | ParaView | 2 | January 6, 2015 09:27 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
Beginner's Question - cannot see grid in ParaView | fishlurch | OpenFOAM | 3 | January 7, 2010 10:49 |
