Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
postProcessing with topoSetDict using planeToFaceZone
Old   February 14, 2022, 20:33
Default postProcessing with topoSetDict using planeToFaceZone
perao is on a distinguished road
Hi all,
I have a topoSetDict with the following instructions:
actions
        name    nozzleOutFaceZone;
        type    faceZoneSet;
        action  new;
        source  planeToFaceZone;
        sourceInfo
           include closest;
           point (0.016 0.00606 0);
           normal (1 0 0);
By running topoSet, I know that the instructions above are correct as I get in the terminal:
Created faceZoneSet nozzleOutFaceZone
    Applying source planeToFaceZone
    Adding faces which form a plane at (0.016 0.00606 0) with normal (1 0 0)
    Found 1 contiguous regions with 1(150) faces
    Selecting region 0 with 150 faces as the closest to point (0.016 0.00606 0)
     faceZoneSet nozzleOutFaceZone now size 150
However, I get an error when trying to use the newly created faceZone for postProcessing with - e.g. pressure:
solver -postProcess -func "faceZoneAverage(name=nozzleOutFaceZone, p)"
Error:
--> FOAM FATAL ERROR:
surfaceFieldValue faceZoneAverage(name=nozzleOutFaceZone,field=p): faceZone(nozzleOutFaceZone):
     Unable to process internal faces for volume field p
and, as a consequence, the result for areaAverage(p) is not written into the postProcessing folder.
Any suggestions on how to fix it? It would be also acceptable an alternative answer using a functionObject instead, which I also could use with -postProcessing.
Using v9.
Kind regards,
perao is offline   Reply With Quote
planetofacezone, postprocessing, toposetdict
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 10:55
Creating an Angled, Smooth Wall with topoSetDict JakeAC OpenFOAM Pre-Processing 1 July 25, 2020 22:37
Issue with topoSetDict file MarineAiry OpenFOAM Running, Solving & CFD 2 September 4, 2019 14:13
The sampled data is not restricted to the defined zone in topoSetDict jiaodanuma OpenFOAM Post-Processing 1 August 14, 2018 08:25
topoSetDict error JohnJohn8 OpenFOAM Pre-Processing 1 August 3, 2016 06:20
