Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
postProcess mesh reading time.
Old   January 16, 2022, 16:44
Post postProcess mesh reading time.
cal
saidc. is on a distinguished road
I have finished a case that has 43 million cells and I'm trying to get some data with using postProcess utility on an hpc cloud. The first part is taking surface vtks from 10 different positions and it worked well with postProcess -func surfaces. Surfaces utility process takes 4 hours and about 1 hour of this is spent reading the mesh. After that I want to take raw datas from lines so I'm using sample utility but this process does not end. Even if I wait for 20 hours, it does not finish reading the mesh. I tried to do parallel and serial but nothing changed. What is the difference between reading for surfaces and reading for sample? Any ideas are appreciated.
Create time
Create mesh for time = 0
Kind regards,
Said.
saidc. is offline   Reply With Quote
Old   February 1, 2022, 13:42
asarmakeeva's Avatar
Ana
asarmakeeva is on a distinguished road
Hi Said, could you attacked full version of code which you using for sampling?
Kind regards, Anastasiia
asarmakeeva is offline   Reply With Quote
Old   February 2, 2022, 09:05
Post
cal
Hi Anastasia,
Here my sample dictionary:
type            sets;
libs            (sampling);
writeControl    writeTime;
interpolationScheme cell;
setFormat       raw;
fields          (T U);
sets
    n1
        type            face;
        axis            x;
        start           (-0.305 0 0.0035);
        end            ( 0.305 0 0.0035);
    n2
        type            face;
        axis            y;
        start           (0 -0.305 0.0035);
        end            (0  0.305 0.0035);
    m1
        type            face;
        axis            x;
        start           (-0.305 0 0.0095);
        end            ( 0.305 0 0.0095);
    m2
        type            face;
        axis            y;
        start           (0 -0.305 0.0095);
        end            (0  0.305 0.0095);
I also tried with controlDict function but it did not work either.
Kind regards,
Said.
postprocess
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
