Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculation of the thrust produced by a propeller
Old   December 3, 2021, 08:53
Post Calculation of the thrust produced by a propeller
hirota tomohiro
hirota is on a distinguished road
Hello everyone.
Thank you very much for your help.
I have been trying to reproduce the rotation of a propeller using the MRF method.
First of all, I would like to thank you all for your advice, which helped me to successfully reproduce the rotation.
At this point, I'm stuck because I don't know the process of calculating the thrust produced by the propeller.
I know that foces and forcecoeffs can calculate the force and torque, but is it possible to calculate the thrust in OpenFOAM?
Is it possible to calculate thrust in OpenFOAM? Or is it common to calculate it using filters in visualization software such as ParaView?
I have attached a mesh of the rotation region in the analysis area.
I would be grateful for any advice.
Thank you very much.
hirota is offline   Reply With Quote
Old   February 4, 2022, 04:04
Claudio Boezio
Ship Designer is on a distinguished road
If the axis of your propeller is parallel to one of the coordinate axes, then you can get the thrust by setting up the forces function object to calculate the forces for the patch of your propeller blades. This is assuming the propeller blades and boss are on their own patch. The force acting parallel to the propeller axis on the propeller patch (pressure and suction side) should be its thrust. I trust you have already looked into the propeller tutorial case that comes with OpenFOAM.
Allow me to observe that the domain might be a bit small if this is a propulsion organ of sorts.
Ship Designer is offline   Reply With Quote
mrf, thrust
Calculation of thrust and torque for propeller aeksberde OpenFOAM Post-Processing 2 October 28, 2019 06:23
Propeller thrust Shrutirao FLUENT 1 March 8, 2019 05:43
Force Calculation in OpenFOAM for Propeller case bmaldi OpenFOAM Running, Solving & CFD 2 May 2, 2018 05:33
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
