Calculating bubble volume in rising bubble simulation |
November 4, 2021, 16:14 |
Venkat Ganesh
Rep Power: 6 |
I'm performing a rising bubble simulation and I'd like to calculate the bubble volume at each writeInterval. I went through some threads and programming guides and came up with a rough code. However I'm not sure how to implement that. I tried creating a function object from a copy of 'vorticity' and changed things around, but the compiler doesn't recognize mesh and alpha1 within the code. Can someone guide in this regard?
Also is there a way I can have the bubble volume written out in a separate text file/csv with just two columns containing time and bubble volume instead of writing it out within the time directory at each writeInterval? Code:
scalar vol; scalar vol_tot_air = 0.0; scalar r_ori = 0.0007505; scalar h_ori = 0.001; scalar vol_ori = 3.14*r_ori*r_ori*h_ori; forAll(mesh.C(), celli) //Loop through all cells { if (alpha1[celli] > 0.5) { vol = alpha1[celli]*mesh.V()[celli]; } else { vol = 0; } vol_tot_air += vol; } scalar vol_final_air = 2*3.14*vol_tot_air; scalar vol_bubble = vol_final_air - vol_ori; |
bubble, bubble diameter, bubble volume, post procesing |
Question about calculating the gas holdup in the bubble column simulation of openFOAM | banananumber1 | OpenFOAM Running, Solving & CFD | 0 | March 23, 2018 04:17 |
bubble rising problem | swamysrikanth | ANSYS Meshing & Geometry | 3 | May 31, 2016 11:09 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
