How to calculate dissipation rate in OpenFOAM |
November 3, 2021, 16:35 |
Farzad Faraji
Rep Power: 8 |
Hello all
I hope you are well. I want to calculate dissipation rate in LES simulation and I find a good code for calculating TKE budget. https://github.com/AndreaDesan/pimpleTKEBudgetFoam But I can not use it since some definitions are different, so I decided to use the definitions in the code(tkeBudget.H); https://github.com/AndreaDesan/pimpl...er/tkeBudget.H Code:
volScalarField kSGS = turbulence->k(); //Instantaneous subgrid-scale tke volScalarField kRes = 0.5*(UPrime & UPrime); //Instantaneous resolved tke kTot = kRes + kSGS; volScalarField epsilonSGS = turbulence->epsilon(); volSymmTensorField SRes = symm(fvc::grad(UPrime)); //Instantaneous resolved fluctuating rate of strain volScalarField epsilonRes=-2*nuLam*(SRes && SRes); //Instantaneous resolved dissipation rate epsilonTot = mag(epsilonRes + epsilonSGS); LESResIndex = kRes/max(kSmall,kTot); //Instantaneous ratio of resolved to total (Resolved + SGS) tke a) The dimension of tke is [m2s(-2)] and "tke rate" must be [m2s(-3)] b) the dimension of dissipation rate must be the same, so I calculate for both epsilonSGS and epsilonRes as below; 1- epsilonSGS = Ce*pow(k,3/2)/delta====>[Ce]*[k^3/2]/[delta]====>[1]*[m3s(-3)]/[m]====>m2s(-3) 2- epsilonRes = nu * (gradU && gradU)====>[m2s(-1)]*[?????]=== I calculate "gradU && gradU" in OpenFoam and dimension was s(-2), so we have [m2s(-1)]*[s(-2)]=m2s(-3). basically epsilonSGS and epsilonRes has the same dimension m2s(-3) which is the same as tke rate m2s(-3). From this I think I have calculated the [?????] correctly. Am I correct? |
November 3, 2021, 17:28 |
#2 | |
Farzad Faraji
Rep Power: 8 |
Maybe this question is a little stupid one. I always read and heard dissipation rate [m2s(-3)], but I never heard about TKE rate. TKE is [m2s(-2)], so TKE rate must be [m2s(-3)] which is the same as dissipation rate. am I correct?
November 8, 2021, 08:27 |
Andrea
Rep Power: 16 |
Not sure from where within code you got "tke rate".
Andrea |
January 11, 2022, 04:44 |
#4 | |
Josh Williams
Rep Power: 5 |
You use UPrime to calculate epsilonRes, but from equation 14 in this paper [1], it appears this would give you epsilonSGS. Instead, based on [1], you should use epsilonRes_ij = nu * (gradU & gradU). Then you can probably get it as a scalar as you appear to have it by taking the trace? I have also seen epsilonRes been calculated as epsilonRes = dkRes/dt [2]. [1] Wacławczyk, M., Pozorski, J. and Minier, J.P., 2004. Probability density function computation of turbulent flows with a new near-wall model. Physics of Fluids, 16(5), pp.1410-1422. [2] Jayaram, R., Jie, Y., Zhao, L. and Andersson, H.I., 2020. Clustering of inertial spheres in evolving Taylor–Green vortex flow. Physics of Fluids, 32(4), p.043306. |
November 24, 2022, 03:20 |
Rep Power: 9 |
Dear Farzad Faraji,
I am having the same problem as you and searched for this thread of yours. Did you solve the problem please? Regards, Shang |
dissipation rate, les, tke les |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 09:51 |
Turbulent Dissipation Rate Concept (epsilon) | elowfoam | Main CFD Forum | 2 | October 9, 2019 15:31 |
Calculate mass flow rate during run time in OpenFOAM | aishk | OpenFOAM | 5 | May 27, 2019 08:03 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
