Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Post Process Heat Conservation Equation
Old   October 27, 2021, 16:34
Post Post Process Heat Conservation Equation
Sameed Akber
sameedakber is on a distinguished road
I am running a a very simple transient simulation: turbulent flow through a rectangular channel; all walls are insulated; constant T,U inlet; buoyantPimpleFoam with sensibleEnthalpy
I cannot satisfy the intregral energy equation in manual post processing. I've attached geometry and integral equation. Since all walls are insulated, AT EACH TIME STEP:
Net energy coming into the domain = rate of change of Energy in control volume
But net energy coming into domain is higher than rate of change of internal energy.
I would appreciate any help. Thank you.
sameedakber is offline   Reply With Quote
buoyantpimplefoam, control volume, energy balance, heat transfer balance
Continuity Equation for multicomponent simulation lordluan CFX 15 May 19, 2020 19:36
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
volumetric conservation equation in PHOENICS code mehdi Phoenics 4 July 31, 2000 15:41
volumetric conservation equation in PHOENICS code mehdi Main CFD Forum 1 July 29, 2000 20:14
