Patches to make the transition from OpenFOAM to CSD softwares |
September 14, 2021, 12:17 |
Rep Power: 5 |
Hello Guys,
I find OpenFOAM really interesting and accurate to model fluid mechanics phenomena such as high winds or so. I am quite new to this software/tool so I try to learn and find my way to the top with the tutorials and forum posts, but I still have some problems. But in general, the modeling of the physical phenomenon is only the first step of a simulation, and the study of the interaction with the structural elements is the following step. What I am trying to achieve is the conversion from OpenFOAM simulation data to another software such as Abaqus/LS-DYNA for the structure response modeling. I think that the easiest way to explain it is with an example: THIS IS AN EXAMPLE: I have a linear increasing wind speed profile based on altitude, which I need to apply on one face of a simple 10x10 meter square building (40 m high), which is quite simplified (4 vertical faces and a roof, no window, no door). I use OpenFOAM for the wind simulation and I need to record the pressure applied by this wind as a function of time on all the faces, to apply these pressures on another CSD software and see the consequences on the building modeled with real materials (imposed). THIS IS HOW I TRY TO SOLVE THIS EXAMPLE I first thought about the steps I have undertaken in order to avoid doing the same thing uselessly multiple times: Step 1: Model the building on a modeling software and export it as a STL geometry. DONE Step 2: Define the areas where I will record the mean pressure applied as a function of time (let’s begin with 1 x 1 meter areas). I wrote the coordinates of the different areas on my notebook. DONE Step 3: Create these recording areas on OpenFOAM. NOT DONE THIS IS WHERE I AM STUCK My first problem is that the meshed geometry with snappyHexMesh doesn’t give me squared cells, so I will need to import the meshed geometry directly, but this problem should be easily resolved as I saw some tutorials on the internet. My second problem, which I need your help with, is how I can indicate to OpenFOAM the cells that will form my pressure recording areas (1 x 1 m areas, which correspond approximately to 10 x 10 cells for nom), and how I can specify the recording method in it. At first, I wanted to record the pressure in one point, at the center of the pressure recording areas, but in some areas, the pressure in this center point is quite different from the average pressure applied in the pressure recording areas. A colleague told me that he saw a note about some “load patch” some time ago, which may be used to solve this problem, but I am not sure about what it refers. I found some post in this forum but it was mostly associated with boundary conditions, inlet flow or outlet flow, so I didn’t find it really interesting for my use. Does someone have some suggestions? Thank you, Have a nice week. |
September 23, 2021, 05:27 |
Rep Power: 5 |
Up, does someone have any idea ?
csd, openfoam, patches |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
Problem with createBaffles - want to make master and slave internal patches | artymk4 | OpenFOAM | 1 | May 22, 2021 05:45 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
