Transforming Fields in OpenFOAM postprocessing |
September 1, 2021, 08:04 |
Jeffrey Johnston
Rep Power: 6 |
I am using a regular hexahedral mesh for solving an atmospheric boundary layer flow. In order to achieve a "quasi-equilibrium" statistically steady state, I am using cyclic boundary conditions on the sides of my domain. However, to avoid the unrealistic "looping" of large coherent structures I am imposing a flow velocity at an angle to the domain (rather than normal to the boundaries) to help break up some of these structures. Here is my issue. OpenFOAM calculates the velocity components parallel to the mesh. But for analysis, I am interested in the stream-wise and cross-stream velocity fields. How can I generate these new velocity components? Is there a utility I can use? Do I need to write a functionObject? Something else? I would like to do this for other vector fields as well. Thank you! |
September 1, 2021, 10:11 |
Jeffrey Johnston
Rep Power: 6 |
Sorry, I should've done a bit more googling before posting here.
After posting, I found another thread that is similar. But I will leave this thread here in case someone else finds it helpful. I think the solution to my problem was to add the following to my controlDict. Code:
transform { type fieldCoordinateSystemTransform; libs (fieldFunctionObjects); fields ( qmean Rmean U Uprime ); coordinateSystem { origin (0 0 0); coordinateRotation { type axisAngle; axis (0 0 1); angle 30; } } } |
transformation, vector field |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 6, 2018 00:48 |
write fields in openfoam database in boundary patch | medmast | OpenFOAM Programming & Development | 7 | February 14, 2017 16:53 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 20:20 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 12:25 |
