Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Custom field function object from wallHeatFlux
Old   August 3, 2021, 13:27
Default Custom field function object from wallHeatFlux
Horst van Gras
HorstvanGrass is on a distinguished road
I want to calculate the Nusselt number at the walls and I wand to implement this in a postprocess field function. My problem is similar to making a custom functionObject but does not solve my problem.
My approach using OpenFoam-v2012
cp wallHeatFlux from src/functionObjects/field/wallHeatFlux/ to a local dir.
Adapt the Make dir
files
NusseltNum/NusseltNum.C
LIB = $(FOAM_USER_LIBBIN)/libCustom
options
XE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/fileFormats/lnInclude \
    -I$(LIB_SRC)/surfMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/lagrangian/basic/lnInclude \
    -I$(LIB_SRC)/lagrangian/distributionModels/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/fvAgglomerationMethods/pairPatchAgglomeration/lnInclude
LIB_LIBS = \
    -lfiniteVolume \
    -lfileFormats \
    -lsurfMesh \
    -lmeshTools \
    -lsampling \
    -llagrangian \
    -ldistributionModels \
    -lfluidThermophysicalModels \
    -lsolidThermo \
    -lincompressibleTransportModels \
    -lturbulenceModels \
    -lcompressibleTransportModels \
    -lincompressibleTurbulenceModels \
    -lcompressibleTurbulenceModels \
    -lchemistryModel \
    -lreactionThermophysicalModels \
    -lpairPatchAgglomeration
Changed every pattern wallHeatFlux to NusseltNum
NusseltNum.H
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | www.openfoam.com
     \\/     M anipulation  |
    Copyright (C) 2016-2017 OpenFOAM Foundation
    Copyright (C) 2016-2020 OpenCFD Ltd.
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
Class
    Foam::functionObjects::NusseltNum
Group
    grpForcesFunctionObjects
Description
    Computes the wall-heat flux at selected wall patches.
    \table
      Operand        | Type              | Location
      input          | -                 | -
      output file    | dat               <!--
                 --> | $FOAM_CASE/postProcessing/\<FO\>/\<time\>/\<field\>
      output field   | volScalarField (only boundaryField) <!--
                 --> | $FOAM_CASE/\<time\>/\<outField\>
    \endtable
Usage
    Minimal example by using \c system/controlDict.functions:
    \verbatim
    NusseltNum1
        // Mandatory entries (unmodifiable)
        type        NusseltNum;
        libs        (fieldFunctionObjects);
        // Optional entries (runtime modifiable)
        patches     (<patch1> ... <patchN>); // (wall1 "(wall2|wall3)");
        qr          qr;
        // Optional (inherited) entries
    \endverbatim
    where the entries mean:
    \table
      Property     | Description                           | Type | Req'd | Dflt
      type         | Type name: NusseltNum               | word |  yes  | -
      libs         | Library name: fieldFunctionObjects    | word |  yes  | -
      patches    | Names of operand patches   | wordList | no | all wall patches
      qr         | Name of radiative heat flux field       | word | no | qr
    \endtable
    The inherited entries are elaborated in:
     - \link functionObject.H \endlink
     - \link writeFile.H \endlink
    Minimal example by using the \c postProcess utility:
    \verbatim
        <solver> -postProcess -func NusseltNum
    \endverbatim
See also
    - Foam::functionObject
    - Foam::functionObjects::fvMeshFunctionObject
    - Foam::functionObjects::writeFile
    - ExtendedCodeGuide::functionObjects::field::NusseltNum
SourceFiles
    NusseltNum.C
#ifndef functionObjects_NusseltNum_H
#define functionObjects_NusseltNum_H
#include "fvMeshFunctionObject.H"
#include "writeFile.H"
#include "volFieldsFwd.H"
#include "HashSet.H"
namespace Foam
namespace functionObjects
                       Class NusseltNum Declaration
class NusseltNum
    public fvMeshFunctionObject,
    public writeFile
protected:
    // Protected Data
        //- Optional list of wall patches to process
        labelHashSet patchSet_;
        //- Name of radiative heat flux name
        word qrName_;
    // Protected Member Functions
        //- File header information
        virtual void writeFileHeader(Ostream& os) const;
        //- Calculate the heat-flux
        void calcHeatFlux
            const volScalarField& alpha,
            const volScalarField& he,
            volScalarField& NusseltNum
public:
    //- Runtime type information
    TypeName("NusseltNum");
    // Constructors
        //- Construct from Time and dictionary
        NusseltNum
            const word& name,
            const Time& runTime,
            const dictionary&
        //- No copy construct
        NusseltNum(const NusseltNum&) = delete;
        //- No copy assignment
        void operator=(const NusseltNum&) = delete;
    //- Destructor
    virtual ~NusseltNum() = default;
    // Member Functions
        //- Read the NusseltNum data
        virtual bool read(const dictionary& dict);
        //- Calculate the wall heat-flux
        virtual bool execute();
        //- Write the wall heat-flux
        virtual bool write();
} // End namespace functionObjects
} // End namespace Foam
#endif
NusseltNum.C
   \\    /   O peration     |
     \\/     M anipulation  |
License
    for more details.
#include "NusseltNum.H"
#include "turbulentFluidThermoModel.H"
#include "solidThermo.H"
#include "surfaceInterpolate.H"
#include "fvcSnGrad.H"
#include "wallPolyPatch.H"
#include "addToRunTimeSelectionTable.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    defineTypeNameAndDebug(NusseltNum, 0);
    addToRunTimeSelectionTable(functionObject, NusseltNum, dictionary);
// * * * * * * * * * * * * * Protected Member Functions  * * * * * * * * * * //
void Foam::functionObjects::NusseltNum::writeFileHeader(Ostream& os) const
    writeHeader(os, "Nusselt is Num");
    writeCommented(os, "Time");
    writeTabbed(os, "patch");
    writeTabbed(os, "min");
    writeTabbed(os, "max");
    writeTabbed(os, "integral");
    os  << endl;
void Foam::functionObjects::NusseltNum::calcHeatFlux
    volScalarField::Boundary& NusseltNumBf = NusseltNum.boundaryFieldRef();
    const volScalarField::Boundary& heBf = he.boundaryField();
    const volScalarField::Boundary& alphaBf = alpha.boundaryField();
    for (const label patchi : patchSet_)
        NusseltNumBf[patchi] = alphaBf[patchi]*heBf[patchi].snGrad();
    const auto* qrPtr = cfindObject<volScalarField>(qrName_);
    if (qrPtr)
        const volScalarField::Boundary& radHeatFluxBf = qrPtr->boundaryField();
            NusseltNumBf[patchi] -= radHeatFluxBf[patchi];
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::functionObjects::NusseltNum::NusseltNum
    const word& name,
    fvMeshFunctionObject(name, runTime, dict),
    writeFile(obr_, name, typeName, dict),
    patchSet_(),
    qrName_("qr")
    volScalarField* NusseltNumPtr
        new volScalarField
            IOobject
                type(),
                mesh_.time().timeName(),
                mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mesh_,
            dimensionedScalar(dimMass/pow3(dimTime), Zero)
    mesh_.objectRegistry::store(NusseltNumPtr);
    read(dict);
    writeFileHeader(file());
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
bool Foam::functionObjects::NusseltNum::read(const dictionary& dict)
    fvMeshFunctionObject::read(dict);
    writeFile::read(dict);
    const polyBoundaryMesh& pbm = mesh_.boundaryMesh();
    patchSet_ =
        mesh_.boundaryMesh().patchSet
            dict.getOrDefault<wordRes>("patches", wordRes())
    dict.readIfPresent("qr", qrName_);
    Info<< type() << " " << name() << ":" << nl;
    if (patchSet_.empty())
        forAll(pbm, patchi)
            if (isA<wallPolyPatch>(pbm[patchi]))
                patchSet_.insert(patchi);
        Info<< "    processing all wall patches" << nl << endl;
    else
        Info<< "    processing wall patches: " << nl;
        labelHashSet filteredPatchSet;
                filteredPatchSet.insert(patchi);
                Info<< "        " << pbm[patchi].name() << endl;
            else
                WarningInFunction
                    << "Requested wall heat-flux on non-wall boundary "
                    << "type patch: " << pbm[patchi].name() << endl;
        Info<< endl;
        patchSet_ = filteredPatchSet;
    return true;
bool Foam::functionObjects::NusseltNum::execute()
    volScalarField& NusseltNum = lookupObjectRef<volScalarField>(type());
    if
        foundObject<compressible::turbulenceModel>
            turbulenceModel::propertiesName
        const compressible::turbulenceModel& turbModel =
            lookupObject<compressible::turbulenceModel>
        calcHeatFlux
            turbModel.alphaEff()(),
            turbModel.transport().he(),
            NusseltNum
    else if (foundObject<fluidThermo>(fluidThermo::dictName))
        const fluidThermo& thermo =
            lookupObject<fluidThermo>(fluidThermo::dictName);
        calcHeatFlux
            thermo.alpha(),
            thermo.he(),
            NusseltNum
    else if (foundObject<solidThermo>(solidThermo::dictName))
        const solidThermo& thermo =
            lookupObject<solidThermo>(solidThermo::dictName);
        calcHeatFlux(thermo.alpha(), thermo.he(), NusseltNum);
    else
        FatalErrorInFunction
            << "Unable to find compressible turbulence model in the "
            << "database" << exit(FatalError);
    const fvPatchList& patches = mesh_.boundary();
    const surfaceScalarField::Boundary& magSf = mesh_.magSf().boundaryField();
        const fvPatch& pp = patches[patchi];
        const scalarField& hfp = NusseltNum.boundaryField()[patchi];
        const scalar minHfp = gMin(hfp);
        const scalar maxHfp = gMax(hfp);
        const scalar integralHfp = gSum(magSf[patchi]*hfp);
        if (Pstream::master())
            writeCurrentTime(file());
            file()
                << token::TAB << pp.name()
                << token::TAB << minHfp
                << token::TAB << maxHfp
                << token::TAB << integralHfp
                << endl;
        Log << "    min/max/integ(" << pp.name() << ") = "
            << minHfp << ", " << maxHfp << ", " << integralHfp << endl;
        this->setResult("min(" + pp.name() + ")", minHfp);
        this->setResult("max(" + pp.name() + ")", maxHfp);
        this->setResult("int(" + pp.name() + ")", integralHfp);
    return true;
bool Foam::functionObjects::NusseltNum::write()
    const volScalarField& NusseltNum = lookupObject<volScalarField>(type());
    Log << type() << " " << name() << " write:" << nl
        << "    writing field " << NusseltNum.name() << endl;
    NusseltNum.write();
    return true;
Everthing compiles fine.
Now is the strange thing what happends
When I type
Solver -postProcess -lib "libCustom" -func NusseltNum
he finds the lib but does not find the function NusseltNum
--> FOAM Warning :
    From static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, Foam::HashSet<Foam::wordRe>&, const Foam::word&)
    in file db/functionObjects/functionObjectList/functionObjectList.C at line 336
    Cannot find functionObject file NusseltNum
What am I doing wrong?
HorstvanGrass is offline   Reply With Quote
Old   August 3, 2021, 13:28
Default Add compiling log
Horst van Gras
./Allwmake
wmake field
    ln: ./lnInclude
Making dependency list for source file NusseltNum.C
g++ -std=c++11 -m64 -pthread -DOPENFOAM=2012 -DWM_DP -DWM_LABEL_SIZE=32  -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter  -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas  -O3   -DNoRepository -ftemplate-depth-100  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/finiteVolume/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/fileFormats/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/surfMesh/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/meshTools/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/sampling/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/lagrangian/basic/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/lagrangian/distributionModels/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/basic/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/transportModels  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/transportModels/compressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/TurbulenceModels/turbulenceModels/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/TurbulenceModels/incompressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/TurbulenceModels/compressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/transportModels/compressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/basic/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/solidThermo/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/chemistryModel/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/reactionThermo/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/specie/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/fvAgglomerationMethods/pairPatchAgglomeration/lnInclude  -iquote. -IlnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/OpenFOAM/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/OSspecific/POSIX/lnInclude    -fPIC -c NusseltNum/NusseltNum.C -o  Make/linux64GccDPInt32Opt/NusseltNum/NusseltNum.o
g++ -std=c++11 -m64 -pthread -DOPENFOAM=2012 -DWM_DP -DWM_LABEL_SIZE=32  -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter  -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas  -O3   -DNoRepository -ftemplate-depth-100  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/finiteVolume/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/fileFormats/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/surfMesh/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/meshTools/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/sampling/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/lagrangian/basic/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/lagrangian/distributionModels/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/basic/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/transportModels  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/transportModels/compressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/TurbulenceModels/turbulenceModels/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/TurbulenceModels/incompressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/TurbulenceModels/compressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/transportModels/compressible/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/basic/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/solidThermo/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/chemistryModel/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/reactionThermo/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/thermophysicalModels/specie/lnInclude   -I/opt/software/OpenFoam/OpenFOAM-v2012/src/fvAgglomerationMethods/pairPatchAgglomeration/lnInclude  -iquote. -IlnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/OpenFOAM/lnInclude  -I/opt/software/OpenFoam/OpenFOAM-v2012/src/OSspecific/POSIX/lnInclude    -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed   Make/linux64GccDPInt32Opt/NusseltNum/NusseltNum.o  -L/opt/software/OpenFoam/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/lib  \
    -lfiniteVolume -lfileFormats -lsurfMesh -lmeshTools -lsampling  -llagrangian -ldistributionModels -lfluidThermophysicalModels  -lsolidThermo -lincompressibleTransportModels -lturbulenceModels  -lcompressibleTransportModels -lincompressibleTurbulenceModels  -lcompressibleTurbulenceModels -lchemistryModel  -lreactionThermophysicalModels -lpairPatchAgglomeration  -o  #MYHomePath/platforms/linux64GccDPInt32Opt/lib/libCustom.so
custom application, field function, postprocess, wallheatflux
Create a custom function object t.oliveira OpenFOAM Programming & Development 13 June 24, 2022 06:41
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Can i take contours from Custom field function i defined ? rahulohlan FLUENT 3 April 18, 2017 14:39
coded function object and field average matthias OpenFOAM Post-Processing 3 June 30, 2014 05:52
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
