how to add additional output not in the time folder |
yan
Rep Power: 5 ![]() |
Hi, I have a running code that it can output some parameter integration in "controldict". I checked the code and that parameter is evaluated each time step. However, they are not available like "U" "p" and are output in the time folder.
I am wondering if I could also have this parameter in the time folder. So that I can check how it looks like (the contours) in the paraview |
output, output fields, output to file |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
How to control output time of pressureTools functions? | Fluido | OpenFOAM Post-Processing | 1 | May 19, 2014 08:49 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
