Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error in obtaining faceIndex
Old   May 3, 2021, 08:09
Default Error in obtaining faceIndex
Sunag R A
sunagra27 is on a distinguished road
Dear All,
I am trying to obtain the face IDs of a particular patch in the geometry. I am using Openfoam 5 version.
I wrote this code shown below.
code
    const fvPatch& mesh = this->patch();
    //const vectorField& Cf = mesh.Cf();
    const fvBoundaryMesh& boundaryMesh = mesh.boundaryMesh();
    forAll(mesh.boundaryMesh()[patch], facei)
            const label& face = boundaryMesh[patch].start() + facei;        // Face index
When I output Cf, it cleary gives the faceCentre coordinates as expected. Likewise, I try to loop over the boundaryMesh patch to obtain label of a face. But, I am unable to execute this. It throws few errors mentioned below. How to clear these errors.?
Error 1:
invalid use of non-static member function ‘const Foam::fvPatch& Foam::fvPatchField<Type>:atch() const [with Type = double]’
/opt/openfoam5/src/OpenFOAM/lnInclude/UList.H:430:30: note: in definition of macro ‘forAll’
for (Foam::label i=0; i<(list).size(); i++)
Error 2:
declared here
const fvPatch& patch() const
What wrong am I doing here in the code?
Any leads will with appreciated.
Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
code stream, controldict, openfoam, post process
Obtaining a clean post production contour plot Lapis1 ANSYS 2 June 22, 2017 06:46
Problem obtaining normal vectors on blade loading line francois louw CFX 10 April 26, 2016 05:47
Obtaining results from simulation geod FLUENT 3 February 27, 2015 10:44
Failing to obtaining the shadow wall Bright ANSYS 0 September 26, 2013 04:50
Obtaining Nu result from internal fin channel andrew FLUENT 2 March 1, 2007 22:38
