Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
calculating TKE budget in OpenFOAM
Old   April 9, 2021, 12:47
Default calculating TKE budget in OpenFOAM
OH
foamUser2020 is on a distinguished road
Hello everyone.
I hope you are having a great Spring.
I would like to calculate the TKE budget, but since I haven't calculate this in OF before, I am not aware of any functions which does that for me.
So I have searched for a while and found https://github.com/sidShinde/tkeBudget on github. I downloaded the code and used wmake. However, when I run it for my case, it does not write out anything in the case folder.
Here is the details:
After wmake, I will have "tkeBudget" folder in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/applications/utilities"
When I run any of the following commands:
- $ pisoFoam -postProcess -latestTime
- $ postProcess -latestTime
I get:
Create time
Create mesh for time = 8000
Time = 8000
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LES
Selecting LES turbulence model dynamicKEqn
Selecting LES delta type cubeRootVol
dynamicKEqnCoeffs
filter simple;
Ce 1.048;
No MRF models present
No finite volume options present
tkeBudget tkeBudgetDict: storing fields:
Pik
Pk
Dk
Tk
Epik
Ck
executing the else statement
End
Also, if I run:
$ postProcess -func tkeBudget -latestTime
I get:
Create time
--> FOAM Warning :
From function static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, Foam::HashSet<>&, const Foam::word&)
in file db/functionObjects/functionObjectList/functionObjectList.C at line 278
Cannot find functionObject file tkeBudget
Time = 8000
Reading fields:
Executing functionObjects
End
AND when I run:
$ postProcess -func tkeBudgetDict -latestTime
I get:
Create time
--> FOAM FATAL IO ERROR:
keyword type is undefined in dictionary "controlDict.functions.tkeBudgetDict.tkeBudgetDict "
file: controlDict.functions.tkeBudgetDict.tkeBudgetDict from line 22 to line 43.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 573.
I really would appreciate if anyone can guide me how to use this function, OR if there are other ways to calculate the TKE budget and plot it.
Thank you,
foamUser2020 is offline   Reply With Quote
Old   April 21, 2021, 05:56
Andrea
Andrea1984 is on a distinguished road
I have hardcoded the calculations of some terms of the TKE budget in this solver: https://github.com/AndreaDesan/pimpleTKEBudgetFoam
It should be fairly easy to extend this to include all the terms in budget.
Hope this helps!
Andrea
Andrea1984 is offline   Reply With Quote
Old   May 14, 2021, 09:52
OH
Originally Posted by Andrea1984 View Post
Hope this helps!
Andrea
Thank you Andrea for your reply. I finished the related project with the same function I mentioned in my post. But I am eager to look at your code and use it for my future needs.
Thanks again.
Calculating the TKE in a Pulsation free jet Falu CFX 2 March 19, 2021 21:52
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
[swak4Foam] Difference in calculating div(U*U) swak4FOAM vs. OpenFOAM codedFunctionObject polo OpenFOAM Community Contributions 7 October 1, 2013 11:22
