Goli
Rep Power: 7 ![]() |
Hi everyone,
I am simulating a 2D incompressible flow with a Reynolds number of 6e6 around a NACA 0012 airfoil with 0-degree angle of attack using simpleFoam with Spalart-Allmaras model. The average y+ is 0.12 (min=0.007, max=0.15) over the airfoil, and I am not using any wall function. The anisotropic grids around the airfoil are structured, and around this layer, the grids are unstructured. I calculate the vorticity in Paraview (v5.9.0) using these two ways: 1- Defining curl(U) in PythonCalculator. 2- Setting U for “Scalar Array” in GradientOfUnstructuredDataSet, then defining “Gradients_3-Gradients_1” in Calculator. Both of these two approaches give the same vorticity profile, and there are some unwanted artifacts, which appear strictly at meshes around the airfoil. I also tried different gradSchemes, but the vorticity profile didn’t improve. Figures 1, 2 and 3 are pictures of these artifacts after I rescale the vorticity to the range -7 and 7 (the range of vorticity at the outlet). Also, as seen in figure 4, the vorticity has very high values on the airfoil, which I am not sure if it is something usual or not. Here are the boundary conditions: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 8.58e-06; boundaryField { inlet { type fixedValue; value uniform 8.58e-06; } outlet { type zeroGradient; } top { type fixedValue; value uniform 8.58e-06; } bottom { type fixedValue; value uniform 8.58e-06; } walls { type fixedValue; value uniform 0; } frontAndBack { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 3.432e-5; boundaryField { inlet { type fixedValue; value uniform 3.432e-5; } outlet { type zeroGradient; } top { type fixedValue; value uniform 3.432e-5; } bottom { type fixedValue; value uniform 3.432e-5; } walls { type fixedValue; value uniform 0; } frontAndBack { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } top { type zeroGradient; } bottom { type zeroGradient; } walls { type zeroGradient; } frontAndBack { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (51.4815 0 0); boundaryField { inlet { type fixedValue; value uniform (51.4815 0 0); } outlet { type zeroGradient; } top { type fixedValue; value uniform (51.4815 0 0); } bottom { type fixedValue; value uniform (51.4815 0 0); } walls { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } // ************************************************************************* // Last edited by Goli; April 14, 2021 at 14:05. |
SU2 inlet profile error | dwstevens | SU2 | 1 | June 8, 2020 16:08 |
Choice of numerical schemes for high accuracy in vorticity | D.B | OpenFOAM Running, Solving & CFD | 1 | February 5, 2018 10:44 |
3D UDF Paraboilc Velocity Profile (Can't Maintain) | Sing | FLUENT | 12 | August 7, 2017 06:25 |
Boundary Profile | E61 | FLUENT | 0 | January 5, 2011 08:13 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
