Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Finding the maximum pressure on a given surface
Old   March 12, 2021, 00:00
Default Finding the maximum pressure on a given surface
Homer Bacanto
hmrbcnt is on a distinguished road
I'm trying to find a way where I can sample the maximum pressure on a given face of an STL I've imported.
So, say I've imported an STL in the shape of a cube within the center of my mesh, and run my simulation using a solver.
Would there be a more efficient way of taking the maximum pressure, or at least the pressure in the center of the face of each side of the cube without having to manually place the probe filters?
hmrbcnt is offline   Reply With Quote
Old   March 12, 2021, 06:42
Simon
Nomis is on a distinguished road
Hi Homer,
assuming that the cube stl is a boundary of your domain you can use a functionObject in your controlDict to monitor the max pressure:
functions
          NAME     {
                  type            surfaceFieldValue;
                  libs             ("libfieldFunctionObjects.so");
                  fields          (p);
                  writeFields no;
                  regionType patch;
                  name         NAMEOFPATCH;
                  operation    max;  // also average or weighted average are possible
Hope this helps. Greeting Simon
Nomis is offline   Reply With Quote
Old   March 14, 2021, 21:52
Homer Bacanto
Originally Posted by Nomis View Post
Hi Homer,
functions
          NAME     {
                  fields          (p);
                  writeFields no;
                  regionType patch;
                  name         NAMEOFPATCH;
Hello, Simon. Thank you for your help! I'm trying to run my code with that openfoam function, but I get some segmentation fault errors, as well as errors about duplicate entries. Here is the segmentation fault error from my log.Solver file.
surfaceFieldValue wallsCopy write:
[2] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[2] #1  Foam::sigSegv::sigHandler(int) at ??:?
[2] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3  Foam::tmp<Foam::Field<double> > Foam::functionObjects::fieldValues::surfaceFieldValue::filterField<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, bool) const at ??:?
[2] #4  Foam::tmp<Foam::Field<double> > Foam::functionObjects::fieldValues::surfaceFieldValue::getFieldValues<double>(Foam::word const&, bool, bool) const at ??:?
[2] #5  bool Foam::functionObjects::fieldValues::surfaceFieldValue::writeValues<double>(Foam::word const&, Foam::Field<double> const&, bool) at ??:?
[2] #6  Foam::functionObjects::fieldValues::surfaceFieldValue::write() at ??:?
[2] #7  Foam::functionObjectList::execute() at ??:?
[2] #8  Foam::Time::run() const at ??:?
[2] #9  ? in "/home/hmrbcnt/OpenFOAM/hmrbcnt-7/platforms/linux64GccDPInt32Opt/bin/blastFoam"
[2] #10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #11  ?[hmrbcnt:09547] *** Process received signal ***
[hmrbcnt:09547] Signal: Segmentation fault (11)
[hmrbcnt:09547] Signal code:  (-6)
[hmrbcnt:09547] Failing at address: 0x3e80000254b
[hmrbcnt:09547] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3f040)[0x7f65655b6040]
[hmrbcnt:09547] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f65655b5fb7]
[hmrbcnt:09547] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3f040)[0x7f65655b6040]
[hmrbcnt:09547] [ 3] /home/hmrbcnt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZNK4Foam15functionObjects11fieldValues17surfaceFieldValue11filterFieldIdEENS_3tmpINS_5FieldIT_EEEERKNS_14GeometricFieldIS6_NS_12fvPatchFieldENS_7volMeshEEEb+0xae)[0x7f653e9f038e]
[hmrbcnt:09547] [ 4] /home/hmrbcnt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZNK4Foam15functionObjects11fieldValues17surfaceFieldValue14getFieldValuesIdEENS_3tmpINS_5FieldIT_EEEERKNS_4wordEbb+0x2d2)[0x7f653ea2f912]
[hmrbcnt:09547] [ 5] /home/hmrbcnt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects11fieldValues17surfaceFieldValue11writeValuesIdEEbRKNS_4wordERKNS_5FieldIdEEb+0xa9)[0x7f653ea2fb19]
[hmrbcnt:09547] [ 6] /home/hmrbcnt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjects11fieldValues17surfaceFieldValue5writeEv+0x1ae)[0x7f653e9e6ade]
[hmrbcnt:09547] [ 7]  in "/home/hmrbcnt/OpenFOAM/hmrbcnt-7/platforms/linux64GccDPInt32Opt/bin/blastFoam"
/home/hmrbcnt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7executeEv+0xe3)[0x7f6566928293]
[hmrbcnt:09547] [ 8] /home/hmrbcnt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0xe2)[0x7f656693bc62]
[hmrbcnt:09547] [ 9] blastFoam(+0x6612)[0x55b756606612]
[hmrbcnt:09547] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f6565598bf7]
[hmrbcnt:09547] [11] blastFoam(+0x771a)[0x55b75660771a]
[hmrbcnt:09547] *** End of error message ***
Any idea what might be causing this? I'm using the blastFoam solver, if the solver matters. Thank you
Old   March 15, 2021, 04:10
Simon
I don't now if the usual functionObjects are supported by blastFoam....
Please check the large number of tutorials within blastFoam and the detailed manual.
There might be one case monitoring the pressure on a patch,
otherwise ask in the blastFoam section of cfd-online.
Greetings Simon
Old   March 17, 2021, 03:53
Homer Bacanto
Hello, thank you once again!
Apparently, most function objects are usable in BlastFoam, but that pressure was a volFieldValue instead of a surfaceFieldValue, so I should use a volFieldValue type instead. I'll have to try this out first.
Thank you so much for your help!
pressure, probing, stl
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 05:42
How to test maximum total pressure and maximum flowrate in centrifugal fan rj26 Main CFD Forum 0 September 19, 2019 23:11
OF-extend: area-averaged pressure drop across one patch and one user defined surface jgross OpenFOAM Post-Processing 0 February 19, 2018 15:03
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
