Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Surfaces output for two regions.
Old   October 28, 2020, 07:31
Default Surfaces output for two regions.
Jan995 is on a distinguished road
I am doing conjugate heat transfer simulations, where I have two different regions. At those separate regions, I want to write temperature fields for specified surfaces. The problem is, that no matter how I write my code, OpenFOAM outputs only surfaces of one regions.
Please find the surfaces files in the attachment.
In controldict I simply put:
functions
include "surfaces"
include "surfaces2"
Thanks for the suggestions.
EDIT:
The above code works. If anyone needs it, take it.
File Type: txt surfaces2.txt (558 Bytes, 11 views)
Jan995 is offline   Reply With Quote
Old   October 31, 2020, 15:31
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
What you've noted is quite true and is a missing feature in OpenFOAM. Supporting it would take some additional work, here's my thoughts or explanation.
The surface sampling are built on top of region/mesh function object, which means their "natural" context is a single mesh region. For sampled patches (for an example) sampling on multiple regions doesn't make much sense. For samplers such as an isoSurface, cutting plane or a triSurface, covering multi-regions makes sense, but still has other issues. Probably cannot sample quantities that only exist in one region (eg, U) - need a zero of undefined for the other region? The various mesh searchers are for a single domain only.
So with these various issues, which sampler types do you think are absolutely needed to handle multi-domain?
olesen is offline   Reply With Quote
[snappyHexMesh] handling of baffle regions or surfaces with zero thickness with snappyHexMesh StSchiff OpenFOAM Meshing & Mesh Conversion 5 March 8, 2017 10:45
[snappyHexMesh] Using snappyHexMesh for multiple enclosed regions richard_vega OpenFOAM Meshing & Mesh Conversion 0 November 13, 2014 15:28
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 02:59
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 13:30
Help with DPM UDF for OUTPUT needed Zhengcai Ye FLUENT 0 January 5, 2004 17:58
