Liquid Holdup Calculations as post processing part of OpenFOAM |
October 19, 2020, 12:16 |
Hello All,
Performed interFoam based multiphase flow two sets of calculations. Set.1: The liquid is flowing from the top to bottom in packing Set.2: Liquid is flowing from top to bottom and simultaneously Gas is flowing from bottom to top (Counter-Current flow modeling). Now, I have post-process data from which I want to calculate the liquid holdup in both sets, how to do that? How to do that in paraview or is there any 'functions-libs' that I can use to do these calculations and extract the values? Also, extract the data of film thickness of the liquid, how to do that? please let me know! I did able to set up pressure drop as 'function-lib'. |
November 5, 2020, 05:17 |
Wenyuan Fan
Rep Power: 9 |
The holdup can be calculated using the volume-weighted average of the alpha field. The film thickness calculation is more complicated, as described in this paper. If you only want to calculate film thickness for few locations, you can simply modify the interfaceHeight function object. |
film thickness, liquid holdup, post processing |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 11:58 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 13:44 |
