Offset on the force derived for each cylinder composing a float |
October 14, 2020, 04:29 |
Constance Clément
Rep Power: 8 |
Hi everyone,
I work on the modelling of a fixed float in waves composed by several cylinders. The simulation is runned with waveFoam to propagate waves (based on interFoam to solve the interface). The mesh is obtained with snappyHexMesh tool. I thus get a patch for each cylinder called “cylinder_i” and a patch called “float” corresponding to the sum of every patch “cylinder_i”. To determine the force on a given patch I add to controlDict: Code:
float { type forces; libs ("libforces.so"); patches ("float"); rhoInf 1000; timeStart 0; log on; writeControl adjustableRunTime; writeInterval 0.01; CofR (0 0 0); } Cylinder_1 { type forces; libs ("libforces.so"); patches ("Cylinder_1"); rhoInf 1000; timeStart 0; log on; writeControl adjustableRunTime; writeInterval 0.01; CofR (0 0 0); } What’s also surprising is that when I sum all the forces shifted derived for the cylinders, I get a total force oscillating around 0 and identical to the force derived with the patch “float”. Thus the offsets are compensated when they are summed. I do not understand this shift, it seems that it is due to the presence of the several cylinders connected. But with interFoam solver, no structural forces are modelled. Have you encountered the same issue when post-treating the force on a specific part of a float ? Thanks a lot, Constance |
cylinder, force, interfoam, libforces.so, wavefoam |
UDF in Fluent | Andrew | Fluent UDF and Scheme Programming | 5 | March 7, 2016 04:38 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
How the force derived on a 2D model? | rikio | FLUENT | 2 | October 11, 2010 22:41 |
How the force derived on a 2D model? | rikio | FLUENT | 0 | October 10, 2010 06:25 |
Attempting to validate force code with 2D cylinder | andrewburns | OpenFOAM Running, Solving & CFD | 41 | January 3, 2008 00:55 |
