Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
cd increase but cl remains constant as AOA increase - possible?
Old   October 8, 2020, 04:43
Default cd increase but cl remains constant as AOA increase - possible?
TWB
quarkz is on a distinguished road
I simulated a 3d wing with back sweep and twist using simpleFOAM (SF) and pimpleFOAM (PF) at AOA from 0 to 10deg
For cd, the results for both solvers are similar and it increases as AOA increases. However, for cl, the increase is small as AOA increases, from around 0.65 at AOA = 0 to 0.77 at AOA = 10. Is this reasonable? Due to the wing twist and back sweep?
I also tried AOA at 12 and 14deg but it's almost the same.
The SF result for cl is lower than that of the PF by abt 10%, but the trend is similar.
We also tried using vortex lattice method (VLM) to do the simulation. For cd, it underpredicts compared to OF, which is expected. However, for cl, it varies from 0.2 at AOA = 2 to 0.9 at 10deg.
Any ideas? Thanks.
quarkz is offline   Reply With Quote
Extremely Small Constant Increase of Heat Transfer Coefficient With Concentration Shomaz ul Haq CFX 6 July 9, 2017 09:06
Chemical properties that are used in Fluent kimej FLUENT 4 August 19, 2011 12:29
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 12:15
