Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculate a new filed from variables in the controldict
Old   October 2, 2020, 05:00
Default Calculate a new filed from variables in the controldict
Carlo_P
Carlo_P is on a distinguished road
I would like to calculate the absoulute presssure starting from the cinematic pressure given from a simpleFoam simulation.
I know that it is possible to do in paraview, but how can be done in openFOAM directly?
something like #calc pAbs=p*1.2+101.325
How can be written in the controldict as functionObject?
Carlo_P is offline   Reply With Quote
Old   October 2, 2020, 10:17
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Carlo,
Depending on what OpenFOAM version you are using, you should manage to do it either with the reference functionObject for ESI's OF versions, or with a combination of scale and add functionObject for the foundation's versions.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   October 2, 2020, 10:51
Carlo_P
For me it is not a version problem, I can use both.
If I understood correctly, I have to put this lines in the controlDict, correclty?
reference1 { // Mandatory entries (unmodifiable) type reference; libs (fieldFunctionObjects); // Mandatory (inherited) entry (runtime modifiable) field <field>; // Optional entries (runtime modifiable) position (0 0 0); scale 1.0; offset 0.0; interpolationScheme cell; // Optional (inherited) entries ... }
In field I have to write p, correct?
Then scale 1.2
but for the absolute pressure? (+101325)
Should go in the offset?
Thanks a lot!
Old   October 2, 2020, 11:28
Yann
Then scale 1.2
This was my first idea, but after having a look at the function definition, I see the scaling factor also effects the offset value:
   r_c = s(f_{c}(t) - f_p + f_{off})
where
        r_c    | field values at cell
        s     | optional scale factor (default = 1)
        f_{c}(t)  | current field values at cell at this time
        f_p    | field value at position
        f_{off}  | offset field value (default = 0)
In order to make it work, you should divide your offset value by the scaling factor to achieve the operation you want to do ( 1.2.p+101325 )
So it should give you something like :
    p_Abs
        type        reference;
        field       p;
        scale       1.2;
        offset      84437.5; //ie 101325/1.2
Of course you can add usual parameters for function objects, such as writeControl and writeInterval to control the function execution.
Let us know if it does the job for you!
Cheers,
Yann
postprocessing; openfoam;
How to define and calculate LES variables rhoPisoFoam Jotazeld OpenFOAM 1 April 3, 2020 05:12
OpenFOAM - Control and Editing of Lagrangian Output Variables gmag OpenFOAM Programming & Development 1 June 25, 2019 13:29
Sensitivity information for custom design variables dghate SU2 0 March 20, 2017 07:39
Need of Help: HowTo designate explicitely unknown variables of a question? Democritus OpenFOAM Programming & Development 6 April 12, 2016 09:38
how to calculate the averaged mass flow along a line over time ? iampolaris OpenFOAM Post-Processing 0 March 10, 2011 23:03
