Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
cyclicAMILduInterface.H OF 8 and dev
Old   September 14, 2020, 16:30
Default cyclicAMILduInterface.H OF 8 and dev
Alejandro
ancolli is on a distinguished road
I am trying to run a postprocess application that works well in OF7. But in OF8 and OFdev it gives me the following error:
Create mesh for time = 211
Using dynamicCode for mixedFvPatchField name at line 90038 in "/home/OF/OpenFOAM/OF-dev/run/folder/211/fi/boundaryField/BC"
Invoking "wmake -s libso /home/OF/OpenFOAM/OF-dev/run/folder/dynamicCode/name"
wmake libso /home/OF/OpenFOAM/OF-dev/run/folder/dynamicCode/name
    Ctoo: mixedFvPatchFieldTemplate.C
In file included from /opt/openfoam8/src/finiteVolume/lnInclude/ddtScheme.C:30,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/ddtScheme.H:357,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/fvcDdt.H:250,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/fvc.H:44,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from /home/OF/OpenFOAM/OF-dev/run/folder/211/fi/boundaryField/BC:91895:
/opt/openfoam8/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:10: fatal error: cyclicAMILduInterface.H: No existe el archivo o el directorio
   39 | #include "cyclicAMILduInterface.H"
compilation terminated.
make: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/mixedFvPatchFieldTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/name/platforms/linux64GccDPInt32Opt/lib/libname_d7eda8e32ac9fdc7d43099ed3f35a712b23758a2.so"
file: /home/OF/OpenFOAM/OF-dev/run/folder/211/fi/boundaryField/BC from line 90038 to line 91894.
    From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
    in file db/dynamicLibrary/codedBase/codedBase.C at line 203.
does anyone know what is happening? or how to solve it?
ancolli is offline   Reply With Quote
Old   October 14, 2020, 15:48
Alejandro
The problem were the codedMixed BC
by commenting the followign part it is solved
/*codeInclude
        #include "fvCFD.H"
        #include "fvcSnGrad.H"
    codeOptions
        -I$(LIB_SRC)/finiteVolume/lnInclude \
            -I$(LIB_SRC)/meshTools/lnInclude
[swak4Foam] compilation error swak4foam dev on fe 4.1 jf_vt OpenFOAM Community Contributions 3 July 19, 2018 13:27
OpenFOAM 1.5 dev LVDH OpenFOAM 98 May 5, 2010 18:01
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:12
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
