sprayFoam - plotting vapor penetration length |
Roman Reinhardt
Rep Power: 6 ![]() |
I am simulating a n-Heptane (C7H16) injection into a cubic chamber, based on experimental data from the Experimental Combustion Network, Sandia National Laboratories. I ran different meshes and made up a shortlist. In order to make the best choice, I wanted to compare my results not only to the experimental results of liquid penetration length, but also to the vapor penetration length. The former wasn't a problem at all to plot, but the latter gives me some headaches at the moment. As i already ran the simulations I am looking for a post processing solution. I am struggling to identify the values of importance from my time directories. The C7H16 file contains the volScalarField for all the cells, but which values do I need? I dont get the structure of that file. I need the values along the x-axis, which is also the axis of injection in my mesh. Can someone give me any advice? I am new to OpenFOAM, and here I really can't go further without any help. I might as well be on the completely wrong path. Greetings, Roman |
plotting, sprayfoam, vapor penetration |
Question about Plotting Vapor Penetration Length | asakusa | OpenFOAM | 1 | August 18, 2020 09:24 |
Plotting Liquid Penetration Length Against Time | eylong | OpenFOAM Post-Processing | 1 | September 23, 2019 06:49 |
Problem with plotting on a curve length | mariusam | CFD Freelancers | 3 | July 26, 2016 16:32 |
Add liquid length to sprayFoam solver | ENKIME | OpenFOAM Running, Solving & CFD | 0 | May 14, 2014 13:11 |
Plotting build up of drag along length of body | RagingPotato | FLUENT | 0 | August 1, 2012 06:50 |
