PostProcessing folder not updated on convergence |
Ben Simpson
Rep Power: 6 ![]() |
My OpenFOAM model is writing data at the defined writeTime in my controlDict but it is not writing the final simulation data to the PostProcessing folder when the convergence criteria is met. Does anyone have any idea what is causing this? For information, I am running buoyantSimpleFoam using the OpenFOAM-dev version. I have several volFieldValue, fieldMinMax and surfaces called in my functionObjects. In my last simulation run, these were writen to the PostProcessing folder at times 1000, 2000, and 3000 but not when the simulation converged at time 3917. Below is my controlDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application buoyantSimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 7000; deltaT 1; writeControl timeStep; writeInterval 1000; purgeWrite 1; writeFormat ascii; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; /*libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" );*/ functions { #include "surfaces" fieldMinMax { type fieldMinMax; libs ("libfieldFunctionObjects.so"); log yes; writeControl writeTime; //writeInterval 1; //mode magnitude; fields ( U p T rho CO2); } CO2 { type scalarTransport; libs ("libsolverFunctionObjects.so"); writeControl timeStep; writeInterval 1; active true; autoSchemes false; nCorr 0; resetOnStartUp false; field CO2; fvOptions { } } comfortAnalysis { type comfort; libs ("libfieldFunctionObjects.so"); metabolicRate 1.2; clothing 0.9; extWork 0.0; executeControl writeTime; writeControl writeTime; } /*modelAverages { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; source all; operation volAverage; fields ( T CO2 U ); }*/ breathingZoneAverages { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name breathingZone; operation volAverage; fields ( T CO2 U PMV PPD ); } spaceAverage { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name spaceZone; operation volAverage; fields ( T CO2 U ); } /*testAverage { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name localTest; operation volAverage; fields ( T CO2 ); }*/ } // ************************************************************************* // Kind regards, Ben |
buoyantsimplefoam, openfoam-dev, postprocessing |
Low Mach number wing/body junction convergence | Zen | SU2 | 6 | May 3, 2019 04:51 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 18:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
