Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
sampleDict with adaptive mesh refinement
Old   July 6, 2020, 06:25
Default sampleDict with adaptive mesh refinement
X
mcfdma is on a distinguished road
Hello.
I am working with a 2D adaptive mesh refinement case. The simulation was run parallelly and upon completion I used reconstructParMesh to get the polyMesh file followed by reconstruct to get all the fields.
However, I am facing issues while post-processing.
sampleDict
	type 		sets;
	libs		("libsampling.so");
	setFormat	csv;
	fields		(alpha.water rhoE grad(Ue) mag(grad(Ue)) U);
	interpolationScheme	cellPoint;
	sets
    line_p0.01mm //0.01  ---------------------------------5
        type        uniform;
        axis        y;
        start       (0.01e-3  0.0      0.0);
        end         (0.01e-3  0.15e-3   0.0);
        nPoints     500;
However, due to refinement, the alpha size which I set to refine in dynamicMeshDict file, is not the same at different time steps. The error I am getting:
Error
Reading fields:
    volScalarField: alpha.water mag(grad(Ue))--> FOAM Warning :
--> FOAM FATAL IO ERROR:
size 68141 is not equal to the given value of 98360
file: /home/m/OpenFOAM/m-v1812/research/DyM/CSF/LMI_DyM2a/0.002/mag(grad(Ue))
    From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int]
    in file /home/m/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/Field.C at line 219.
End
How can I sample???
mcfdma is offline   Reply With Quote
amr, sampledict
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges olek.warc OpenFOAM Meshing & Mesh Conversion 1 August 31, 2018 12:31
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
