Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Only Zeros In icoUncoupledKinematicParcelFoam
Old   May 20, 2020, 05:00
Default Only Zeros In icoUncoupledKinematicParcelFoam
SimonStar's Avatar
Simon
SimonStar is on a distinguished road
Hello guys.
sorry if you red this in another thread before. Since its not a good style to ask questions in a already existing thread I'm opening a new one.
I have a roblem with the openfoam icoUncoupledKinematicParcelFoam-Solver.
I took the hopper-tutorial from that solver. If I run it, it gives me normal results.
Now I am trying to change the geometry to a simple cube just to make the first step to adapt it to my special case. But the solver is showing in each iteration 0 partikles. Does someone know why it is like that?
Here is the Output after each iteration:
Time = 0.0005
Evolving kinematicCloud
Solving 3-D cloud kinematicCloud
Cloud: kinematicCloud
    Current number of parcels       = 0
    Current mass in system          = 0
    Linear momentum                 = (0 0 0)
   |Linear momentum|                = 0
    Linear kinetic energy           = 0
    model1:
        number of parcels added     = 0
        mass introduced             = 0
    Rotational kinetic energy       = 0
In the folder: [lastTimestep]/uniform/lagrangian/kinematicCloud are two files after the simulation:
cloudProperties:
processor0
    particleCount   0;
and kinematicCloudOutputProperties
injectionModel
    model1
        massInjected    0;
        nInjections     245;
        parcelsAddedTotal 0;
        timeStep0       0;
So how can there be 245 Injections when the number of particles is zero?
I am not showing the kinematicCloudPropertiesbecause its producing the same error if I change it.
Thank you for any suggestions
Simon
SimonStar is offline   Reply With Quote
Old   May 25, 2020, 08:58
Wink
SimonStar's Avatar
Simon
Hello everyone,
I think I got a solution to my problem. Its a mistake thats costing time if you're a beginner. I hpe to save others time by writing this.
The problem was that I changed the geometry to a smaller one without changing the particle injection positions. The ressult was that all particles were injected into nowhere...
I'm still interessted in going further:
1. What is the best way to inject the particles instead of at the same time over a time period?
2. Can I also use the cinematicCloudPositions-File for this or do I have to go a completely diffrent way?
Thank you
Simon
opefoam7, problem, solver error, uncoupledkinematicparcel
All zeros: Skin Friction Coefficient, Heat Flux, Y Plus LetsCFD SU2 1 June 18, 2016 12:12
Fluent displays Zeros.. vishnu_240 FLUENT 2 January 30, 2014 00:34
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[Help Please], Trouble Using UDF to Import Velocity Data -- But All Zeros :( rockymountai FLUENT 1 November 11, 2009 17:30
Please Help, Using UDF to Import Velocity Data -- But All Zeros :( rockymountai FLUENT 0 November 10, 2009 16:47
