Sampling fields values passing through multiple windows |
May 1, 2020, 12:14 |
Ben Simpson
Rep Power: 7 |
Hi CFD Guru's,
I have a natural ventilation model of a building which currently has 20 open windows. For the ventilation metrics I need to find out the total contaminants (CO2), air velocity and temperature entering and leaving the building through the windows. I am not sure what is the best/most efficient method of achieving this. Currently I have a surfaces file (see below) which provides a separate raw file for each field and each window. Is there a method which would allow me to sample the cells along a plane in the centre of the windows, which would provide a single file per field for all of the windows? I am running the model in OpenFOAM-v1812 using the buoyantBoussinesqSimpleFoam solver. Any help/advise on this topic would be very much appreciated. Kind regards, Ben Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ surfaces { type surfaces; libs ("libsampling.so"); writeControl writeTime; surfaceFormat raw; fields (U T CO2); interpolationScheme cell; surfaces ( Window1 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (0.85 0.175 2.2); normal (2 0 0.5); } interpolate true; } Window2 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (3.85 0.175 2.2); normal (2 0 0.5); } interpolate true; } Window3 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (6.85 0.175 2.2); normal (2 0 0.5); } interpolate true; } Window4 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (9.85 0.175 2.2); normal (2 0 0.5); } interpolate true; } Window5 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (12.85 0.175 2.2); normal (2 0 0.5); } interpolate true; } Window6 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (0.85 0.175 0.7); normal (2 0 0.5); } interpolate true; } Window7 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (3.85 0.175 0.7); normal (2 0 0.5); } interpolate true; } Window8 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (6.85 0.175 0.7); normal (2 0 0.5); } interpolate true; } Window9 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (9.85 0.175 0.7); normal (2 0 0.5); } interpolate true; } Window10 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (12.85 0.175 0.7); normal (2 0 0.5); } interpolate true; } Window11 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (0.85 15.55 2.2); normal (2 0 0.5); } interpolate true; } Window12 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (3.85 15.55 2.2); normal (2 0 0.5); } interpolate true; } Window13 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (6.85 15.55 2.2); normal (2 0 0.5); } interpolate true; } Window14 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (9.85 15.55 2.2); normal (2 0 0.5); } interpolate true; } Window15 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (12.85 15.55 2.2); normal (2 0 0.5); } interpolate true; } Window16 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (0.85 15.55 0.7); normal (2 0 0.5); } interpolate true; } Window17 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (3.85 15.55 0.7); normal (2 0 0.5); } interpolate true; } Window18 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (6.85 15.55 0.7); normal (2 0 0.5); } interpolate true; } Window19 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (9.85 15.55 0.7); normal (2 0 0.5); } interpolate true; } Window20 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (12.85 15.55 0.7); normal (2 0 0.5); } interpolate true; } ); } // ************************************************************************* // |
buoyancy driven flow, natural ventilation, openfoam 1812 |
Sampling fields data from regions (cellZoneSet) | caduqued | OpenFOAM Post-Processing | 6 | November 22, 2012 10:28 |
accepted values in some fields in fluent setup | zikozaki01 | FLUENT | 1 | February 23, 2012 11:45 |
[swak4Foam] funkySetFields and multiple sets and fields | mturcios777 | OpenFOAM Community Contributions | 1 | January 7, 2012 18:51 |
Comparing values of two different fields | sambatra | OpenFOAM Running, Solving & CFD | 0 | October 30, 2009 05:13 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 10:15 |
