[sampleDict] has error with [externalWallHeatFluxTemperature] |
April 25, 2020, 22:50 |
Pu Gong
Rep Power: 8 |
I was using buoyantPimpleFoam to model a heat source in a room and everything seems well with the simulation processing.
However, when I was trying to use sampledict to get data of field T I got the following error. [CODE] Time = 0 Reading fields: volScalarFields: alphat s nut p_rgh p T--> FOAM Warning : From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int] in file /home/minecraftgp/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/Field.C at line 325 Reading "/home/minecraftgp/openFoam_case/buoyantPImpleFoam/Ibrahim/0/T.boundaryField.heatplane" expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. k epsilon volVectorFields: U Executing functionObjects Time = 60 Reading fields: volScalarFields: alphat s nut p_rgh p T--> FOAM Warning : --> FOAM FATAL IO ERROR: keyword Ta is undefined in dictionary "/home/minecraftgp/openFoam_case/buoyantPImpleFoam/Ibrahim/60/T.boundaryField.heatplane" [CODE] I can get the sampleDict results for t= 0s. But for t=60s the error shows there is lack of keyword Ta in my 'heatplane' BC setting in T file. The following is my BC setting of 'heatplane' for t=0s, as can see the BC type is externalWallHeatFluxTemperature and I have already set the keyword Ta. But I dont how to set Ta on 60s because they are calculated based on 0... [CODE] heatplane { type externalWallHeatFluxTemperature; mode power; Q 20; kappaMethod fluidThermo;// calculate kappa=alphaEff*thermo.Cp relaxation 0.1; Ta 298.15; value 300; // place holder } [CODE] I am confused why sampledict the field T will need the value of Ta from externalWallHeatFluxTemperature? Any help would be appreciated |
April 25, 2020, 22:53 |
Pu Gong
Rep Power: 8 |
Time = 0 Reading fields: volScalarFields: alphat s nut p_rgh p T--> FOAM Warning : From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int] in file /home/minecraftgp/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/Field.C at line 325 Reading "/home/minecraftgp/openFoam_case/buoyantPImpleFoam/Ibrahim/0/T.boundaryField.heatplane" expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. k epsilon volVectorFields: U Executing functionObjects Time = 60 Reading fields: volScalarFields: alphat s nut p_rgh p T--> FOAM Warning : --> FOAM FATAL IO ERROR: keyword Ta is undefined in dictionary "/home/minecraftgp/openFoam_case/buoyantPImpleFoam/Ibrahim/60/T.boundaryField.heatplane" |
April 25, 2020, 22:55 |
Pu Gong
Rep Power: 8 |
heatplane { type externalWallHeatFluxTemperature; mode power; Q 20; kappaMethod fluidThermo;// calculate kappa=alphaEff*thermo.Cp relaxation 0.1; Ta 298.15; value 300; // place holder } |
