Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sample Set - Creates folder for each timestep
Old   April 22, 2020, 08:41
Default Sample Set - Creates folder for each timestep
Herman Bordal
Bordal is on a distinguished road
Dear all
I am sampling a set of lines from a running transient case. The issue is that each line gets a separate folder, containing a new subfolder with each timestep. Ideally should one line get a single file, and all timesteps could be added to this file. Such that one obtain a set of larger files, instead of a heap of folders containing smaller files. Any help avoiding too many folders for linux to handle would be much appreciated.
ive appended a bunch of these lines in the controlDict file
Line359{
type sets;
functionObjectLibs ("libsampling.so");
writeControl timeStep;
outputInterval 1;
interpolationScheme cellPoint;
setFormat raw;
sets
data
type lineUniform;
axis distance;
start (0.07198903405126017 -0.00125657326348448 0);
end (1.1518245448201627 -0.02010517221575168 0);
nPoints 500;
fields (U);
In advance, thanks
Bordal is offline   Reply With Quote
folders, line, sampling, set
does Hyperthreading affect the application of UDF? SJSW Fluent UDF and Scheme Programming 11 October 10, 2018 23:28
Remeshing for Rotation in CFX via ICEMCFD gera CFX 3 September 23, 2017 13:29
sample does not create folder for all times joel.lehikoinen OpenFOAM Post-Processing 0 June 3, 2011 05:07
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
Problems with installation jonititan OpenFOAM Installation 4 November 6, 2005 05:16
