Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
postProcess -field U -func mag, Why it gives error?
Old   April 9, 2020, 13:39
Wink postProcess -field U -func mag, Why it gives error?
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi guys.
Ok, I already know that I can use the following code and compute the mag of U easily:
postProcess -func "mag(U)"
There is a big but here. Checkout this command:
postProcess -fields "(p U)" -func wallShearStress
It is mentioned in the OpenFOAM user guide and it works just fine. I guess you guess what my question is now; why I cannot get the mag of U by the following command:
It gives me the following error:
Time = 1
Reading fields:
    volVectorFields: U
Executing functionObjects
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type volScalarField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type surfaceScalarField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type volVectorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type surfaceVectorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type volSphericalTensorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type surfaceSphericalTensorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type volSymmTensorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type surfaceSymmTensorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type volTensorField
--> FOAM Warning :     functionObjects::mag mag cannot find required object <fieldName> of type surfaceTensorField
--> FOAM Warning :     functionObjects::mag mag failed to execute.
What are the differences?
Cheers & Stay Healthy!
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   April 9, 2020, 15:08
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
You need a configuration file in the system directory, like this:
https://github.com/OpenFOAM/OpenFOAM...ing/fields/mag
change the <fieldName> to U
and then:
postProcess -func mag -field U
finally, you will get mag(U) in the $time directory.
https://openfoam.top
zhangyan is offline   Reply With Quote
Old   April 9, 2020, 15:16
Mojtaba.a's Avatar
and then:
Thank Yan,
But I already have the configuration file in the OpenFOAM caseDicts directory. However, I copied the file into my system folder too:
foamGet mag
I tried the command but again the same error happened.
Cheers
Old   April 9, 2020, 15:18
zhangyan's Avatar
Yan Zhang
Don't forget to change the <fieldName> to U
Old   April 9, 2020, 15:21
Mojtaba.a's Avatar
Yea, that did the trick. Thanks!
However, I get two warnings whenever I try to compute mag(U) field using any method. Do you know why?
Time = 1
Reading fields:
    volVectorFields: U
--> FOAM Warning :     functionObjects::mag mag cannot find required object U of type volScalarField
--> FOAM Warning :     functionObjects::mag mag cannot find required object U of type surfaceScalarField
    functionObjects::mag mag writing field: mag(U)
Old   April 9, 2020, 15:22
zhangyan's Avatar
Yan Zhang
Me too. Just forget it.
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
