Quantifying interface compression (interFoam) |
February 10, 2020, 09:53 |
Mike
Hello all,
I am using interFoam for several multiphase simulations. In the alpha (volume fraction) equation, there is a constant cAlpha that has to do with interface compression. I noticed that for some cases, cAlpha has a large influence whereas for other cases it does not. I understand why, from the equations, but I would like to quanitfy / visualize this. In order to do this, I would like to know the value of phic and phir which appear in the alphaEqn.H file (see equations from that file below). phic = mag(phi/mesh.magSf()); phic = min(interface.cAlpha()*phic, max(phic)); surfaceScalarField phir = phic*interface.nHatf(); I tried using output stream and a swakExpression to accomplish this, but due to its surfaceScalar nature it seems quite hard as it is only defined for each cell surface and not just for each cell like volumeScalars. Can anyone help me with suggestions how I can quantify or visualize phir and/or phic? Thanks! |
April 27, 2023, 06:51 |
Hosein
Rep Power: 15 |
Hi there,
I just came across this post and it certainly is too late but just wanted to mention that the same issue was addressed in another thread "Visualisation of a surfaceScalarField with paraview". As Mattijs said you need to use Glyph... |
calpha, interfoam, openfoam, quantify, surfacescalarfield |
How to have sharp interface in nano scale two phase flow problem using interFoam | hosseinfathi | OpenFOAM Programming & Development | 10 | April 9, 2017 10:07 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
abnormal temperature near interface when adding energy equation to interFoam | houkensjtu | OpenFOAM | 4 | June 26, 2013 14:40 |
VOF interface compression and mesh size | idrama | OpenFOAM | 1 | September 26, 2010 07:36 |
