Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
patchAverage on slurm cluster
Old   February 5, 2020, 06:43
Default patchAverage on slurm cluster
hellsign48 is on a distinguished road
I'm using old version of OF so patchAverage works on my work station with no problems:
patchAverage p bottom > pressure.txt
however when I do the same on cluster it gives no results and just makes an empty file. Does anyone know if it should be done different way on clusters?
hellsign48 is offline   Reply With Quote
Old   February 5, 2020, 09:11
Agustín Villa
agustinvo is on a distinguished road
When you run patchAverage in you local workstation, is the case decomposed or not? And what about in the slurm cluster?
If you are running the command in decomposed timeSteps, the problem might come up from there.
agustinvo is offline   Reply With Quote
Old   February 5, 2020, 09:15
In both cases it's in reconstructed case. I'm also not getting any error message or complain. It does something for couple of seconds but doesn't give any output (on cluster).
Old   February 10, 2020, 17:57
JNSN's Avatar
Jan
JNSN is on a distinguished road
Are you running with srun command?
JNSN is offline   Reply With Quote
Old   February 11, 2020, 04:41
I tried ruining it with sbatch and also with just patchAverage in terminal. Still no luck.
Old   February 11, 2020, 07:19
JNSN's Avatar
Jan
With 'in terminal ' you mean outside slum? No interactive console?
Old   February 11, 2020, 07:55
Yes I meant outside slurm. This way I use roconstructPar without any problems.
cluster computing, openfoam, patchaverage, slurm
FSI simulation in SLURM cluster (input file and script) Lara Gonçales Structural Mechanics 0 January 20, 2020 16:45
FSI coupling simulation in SLURM Cluster Claudio.M ANSYS 1 January 7, 2019 01:49
[Other] Basic questions about OpenFOAM cluster running and installing Fauster OpenFOAM Installation 0 May 25, 2018 16:00
SAP cluster resource/services not coming online on cluster node 2 Nthar1@yahoo.com Hardware 0 May 9, 2017 06:55
Why not install cluster by connecting workstations together for CFD application? Anna Tian Hardware 5 July 18, 2014 15:32
