Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
paraFoam not working in CFDEM setup
Old   December 5, 2019, 00:22
Default paraFoam not working in CFDEM setup
Jagan Mohan
jagan1mohan is on a distinguished road
Hello Team,
Greetings. I would like to bring to your notice that when we install OpenFOAM alone (using commands on OpenFoam webpage, https://openfoam.org/download/6-ubuntu/), all the commands of paraFoam such as -block, -builtin, -case work perfectly fine.
However, when we install CFDEM setup (as per https://www.cfdem.com/media/CFDEM/do...ng_Manual.html), we have everything working, that is, OpenFOAM, LIGGGHTS and coupled OpenFOAM - LIGGGHTS but only the paraFoam does not work.
Can someone let me know how to fix this? When I issue paraFoam in case folder, I get the following message.
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
It does not work even after issuing these commands and ends up into new error.
Allwmake applications/utilities/postProcessing/graphics/PVReaders
ERROR: ParaView not found in /home/jb/OpenFOAM/ThirdParty-5.x/platforms/linux64Gcc/ParaView-5.4.0
Actually, the above folder does not exist. Can someone let me know how to fix this?
Thank you,
jagan1mohan
jagan1mohan is offline   Reply With Quote
cfdem, parafoam problem, paraview
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 5 March 23, 2022 09:09
[OpenFOAM] QXcbConnection: Could not connect to display :0 Schurl ParaView 7 March 11, 2019 07:19
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam powerline332 OpenFOAM Installation 3 May 24, 2018 22:16
Taylor Couette Setup and Boundary Conditions DaSh OpenFOAM Pre-Processing 2 September 28, 2017 13:02
paraFoam command no longer working after upgrading to Ubuntu 13.04 c_dowd OpenFOAM Installation 9 June 24, 2013 09:28
