Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Extract body points coordinate snappyhexmesh
Old   August 8, 2019, 11:01
Default Extract body points coordinate snappyhexmesh
Andrew
Astan is on a distinguished road
Hi guys, i have done a simple mesh of an airfoil, i would like to know how to extract the coordinates of points of the mesh that are on the airfoil patch
Thanks you for any answers
Anstan
Astan is offline   Reply With Quote
Old   August 14, 2019, 04:45
anonymous
simrego is on a distinguished road
Hi!
You need it for external processing? This is a pretty brute force solution, but in the polyMesh/boundary file you can find the starting face of that patch and the number of faces. then in the polyMesh/faces file you can find the points for these faces. In the polyMesh/points file you find the coordinates for these points.
But there is a much simpler way using paraView. Open the case, load only the needed patch, create a SpreadSheet view, and you will find the coordinates in the Points column. And you can export it as a csv file. This is simpler, but the first method is more challenging
simrego is offline   Reply With Quote
Old   August 15, 2019, 04:02
Andrew
Hi simrego thanks you very much for the help!
Astan
[snappyHexMesh] snappyHexMesh, new timestep creation and field and mesh dont have the same #points Loekatoni OpenFOAM Meshing & Mesh Conversion 1 November 23, 2018 10:11
Deformations in a Coordinate System that rotates (moves) with the solid body Pumpov Structural Mechanics 4 September 10, 2018 09:00
sample utility of OF2.3.1 provides less points aCFDuser OpenFOAM Post-Processing 7 May 1, 2017 22:25
TimeVaryingMappedFixedValue best practice to extract subset points and fields podallaire OpenFOAM Running, Solving & CFD 6 May 21, 2014 11:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
