Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to compute Phi field having U (OFv6)
Old   July 31, 2019, 11:43
Default How to compute Phi field having U (OFv6)
OOS
oobiols is on a distinguished road
Dear OpenFOAMers,
I am using Openfoam-v6 and I want to solve a simple benchmark, let's say, laminar flow around a cylinder (Re~50).
The thing is that I want to give it my own initial condition. In the 0 folder, I would use a customized U field. How can I tell OpenFOAM to compute the phi scalar field from this U vector field? It should be possible because I have U and the mesh is correctly created using blockMesh. For future iterations, phi is computed and shows up in the timesteps folders, but not for the 0 folder. Any ideas?
I know that the SIMPLE algorithm, for instance, computes phi as :
phi = flux(U)
In older versions of OF, it is computed as:
phi = linearInterpolate(U) & mesh.Sf()
Is it possible to add this as a function object or a function in the controlDict? How?
I have tried to compile my own custom function object to get it but I am not being succesful. I am using the OF docker. Thank you very much!
oobiols is offline   Reply With Quote
Old   July 31, 2019, 17:26
OOS
Actually, I can make the question more general:
- How to compute the phi field from a U field given by me?
Thanks a lot.
custom defined function, function objects, phi field
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
field functions - table crevoise STAR-CCM+ 3 March 26, 2013 10:37
Field functions and table crevoise Siemens 0 March 20, 2013 11:51
Accessing phi field for sampling plane francesco85 OpenFOAM Post-Processing 1 August 5, 2011 06:49
To compute Average flowfield with oodles flying OpenFOAM Running, Solving & CFD 3 May 5, 2009 09:46
