Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error while postProcessing icoFoam case to get grad(U)
Old   July 27, 2019, 19:02
Default Error while postProcessing icoFoam case to get grad(U)
Shashank
shashanktiwari619 is on a distinguished road
I am trying to post-process U data from a simulation in icoFoam to get the grad(U). I use the command
postProcess -latestTime -func 'grad(U)'
After running the above command I get the following warning.
PHP Code:
--> FOAM Warning :     functionObjects::grad grad(Ucannot find required object U of type volScalarField
--> FOAM Warning :     functionObjects::grad grad(Ucannot find required object U of type surfaceScalarField
P.s. I am calculating grad(U) to ultimately calculate the turbulent dissipation rate (\epsilon). Any help regarding this would be appreciated.
shashanktiwari619 is offline   Reply With Quote
Old   July 29, 2019, 03:47
Batuhan Çakar
thonix is on a distinguished road
Did you include grad functions in your system or controlDict??
Can you snap a shot of them may the problem is including
thonix is offline   Reply With Quote
gradient, post processing
forcecoeffs with icoFoam... No postProcessing directory MurtazaAbbas OpenFOAM Post-Processing 1 February 9, 2016 09:49
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Turbine spiral case postprocessing mateus FLUENT 0 April 24, 2008 04:24
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Body force - Does it work? Jan Rusås CFX 5 August 27, 2002 10:50
