Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Directional Plane Averaging in Pipe
Old   July 22, 2019, 08:49
Question Directional Plane Averaging in Pipe
George Sof
lastjedivol is on a distinguished road
Hello everyone, i am recently working towards a simple pulsating flow in a pipe simulation, using OpenFoam. I am interested in averaging velocity (Y,Z plane) towards (X) direction. The problem seems quite simple, but i have not found any code or any post-process tool in order to do this job in Paraview/OpenFoam.
Any help would be appreciated!
lastjedivol is offline   Reply With Quote
Old   July 30, 2019, 11:02
camel is on a distinguished road
Hi!
So you are trying to perform the space averaging? Or I missed something?
In case you want to perform space averaging, have a look at the postChannel utility code. This should help you.
Moreover, have a better look at the forums threads. There are some threads and comments on space averaging of LES pipe flow results. This should also help you.
Best regards!
camel is offline   Reply With Quote
averaging, directional, opeanfoam, pipe
[Commercial meshers] faceSet of a cutting plane for a internal patch definition RubenGutiii OpenFOAM Meshing & Mesh Conversion 1 April 17, 2019 06:10
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 01:19
Mixing plane with implicit averaging (beta feature) evan247 CFX 0 December 19, 2016 16:53
Plane stress and plane strain cases for stress analysis Sargam05 OpenFOAM 0 May 3, 2013 19:16
Double Walled Pipe Boundary dahvqaz FLUENT 2 December 5, 2012 11:14
