Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Logging/writing postProcess values
Old   June 26, 2019, 21:12
Default Logging/writing postProcess values
Brett
Bdew8556 is on a distinguished road
Hey foamers,
I've got a simulation where I'm interested in knowing information at the patches once its converged.
I know how to do this in the command line, for example:
postProcess -func 'patchAverage(name=outlet,p,U)' -latestTime
will give me the patch average of pressure and velocity on the patch 'outlet'. All good.
However how do I get it to log/write this information to a text file?
What if I wanted to repeat this command for several other patches and have their information recorded in the same log file??
Any thoughts??
Bdew8556 is offline   Reply With Quote
Old   June 27, 2019, 05:53
Zander Meiring
yambanshee is on a distinguished road
in linux, having a > at the end of a command tells it to write to a file rather than a terminal. If it's a two of them (ie: >>) then it only appends to a file, instead of rewriting.
So to accomplish what you want:
postProcess -func 'patchAverage(name=outlet,p,U)' -latestTime > output
and it will create the file called output, and write in there instead of terminal.
Alternatively, look into adding functions in your control dict. For patch averaging for example, you'd want something along the lines of this at the bottom of your controldict file:
functions
	patchAverage
    		#includeEtc "caseDicts/postProcessing/surfaceFieldValue/surfaceRegion.cfg"
    		operation       areaAverage;
   		fields          (p, U);
		writeControl    runTime;
		writeInterval   1;
for more information, read up on function objects at https://www.openfoam.com/documentati...n-objects.html
yambanshee is offline   Reply With Quote
Old   June 28, 2019, 01:20
Brett
Thanks for that!
That's definitely the nicest response I've ever had, usually people just pick out what they think is wrong with your comment!
I'm using OpenFoam on windows, are the arrows ( >, >> ) still the same?
I wonder if you could elaborate a bit more on:
Thanks heaps again
Old   July 1, 2019, 06:00
Zander Meiring
Originally Posted by Bdew8556 View Post
Thanks for that!
Thanks heaps again
-I have no idea about OF for windows
the include grabs the file within the quotation marks from the directory 'etc', which is located in your openFoam install file path. Most of these type of postProcessing scripts are small scripts built up on top of each other, and the key is finding one you are interested in. My recommendation is to navigate to this folder. Within it, there are files with a .cfg extension, and files with no extension (at least that's the case on linux). These extensionless ones show demonstrations of how to use different post processing functions. For example, in postProcessing/surfaceFieldValue/ there is a file called 'patchAverage' which contains:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Web:      www.OpenFOAM.com
     \\/     M anipulation  |
Description
    Calculates the average value of one or more fields on a patch.
name    <patchName>;
fields  (<field names>);
operation average;
#includeEtc "caseDicts/postProcessing/surfaceFieldValue/patch.cfg"
This file shows you everything you need in the function objects to perform a patch average, and you can copy the middle straight into your functions in controlDict, with your specific options edited. In this case, that would be the 'name' and 'fields' variables
openfaom, postprocess, scripting
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
Velocity values are normal but pressure values are too big rv82 OpenFOAM Running, Solving & CFD 4 April 13, 2015 04:59
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
Plotting raw data values Wilesco Siemens 0 January 5, 2006 06:34
