Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Spatial average of viscosity
Old   May 23, 2019, 07:19
Default Spatial average of viscosity
Nat K
nskelly is on a distinguished road
I have ran some shear thinning simulations of a backward facing step in OpenFOAM and would like to calculate the spatial average of viscosity across the domain.
Is this possible to do in paraview? I know of the postSpanwiseAverage toolbox but this seems to just average the velocity.
The other alternative is to use Matlab, but I am a bit unsure how to do it in there also as it would read in cell data but the points are not uniform due to the meshing.
Any help would be great.
nskelly is offline   Reply With Quote
Old   June 13, 2019, 07:09
Agustín Villa
agustinvo is on a distinguished road
did you created you mesh with blockMesh? If you know python, try to use fluidfoam, and you can load the cells in the order they where created (with blockMesh is more or less evident in function or the order of your blocks), and perform the average after some matrix manipulation.
agustinvo is offline   Reply With Quote
Old   June 19, 2019, 07:31
Zander Meiring
yambanshee is on a distinguished road
In parafoam, you can use the filter 'integrate variables' with the option 'divide cell data by volume' turned on. This will open a spreadsheat view up, and by selecting the attribute 'cell values' in the drop down menu, you can get all your properties spatially averaged.
If you would like to do it in a software like matlab, i would recommend using the filter meshQuality and setting Hex/quad/etc... to volume, and then saving that filter as a csv. This will give you all your fields per cell, along with that cell's volume.
In 1d, a simlar process can be used with the filter 'arcLength', which I use to create circumferentially averaged data with varying heights.
Regards!
yambanshee is offline   Reply With Quote
backward facing step, shear thinning, spatial average, viscosity
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
What is linear eddy viscosity toboto Main CFD Forum 2 January 12, 2018 19:30
0 concentration specie impacting viscosity value ChrisA OpenFOAM Running, Solving & CFD 1 March 16, 2013 20:58
solidification viscosity governed through an additional variable l.te CFX 8 September 13, 2012 20:19
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
