Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
run-time post-processing for uniformity index
Old   April 16, 2019, 09:18
Default run-time post-processing for uniformity index
jcw
Christian Wolf
jcw is on a distinguished road
Hello!
I would like to start a run-time post-processing: The output should be the 'uniformity index' (UI) with respect to velocity at a certain outlet patch. The problem is: How do I implement at function with is evaluated during simulation run. I use OF4.1 and do not have swak4Foam installed.
Thanks for advise!
jcw is offline   Reply With Quote
Old   April 16, 2019, 14:40
clapointe is on a distinguished road
You can create a custom function object and put it in controlDict. It will be compiled and used at runtime. See :
https://github.com/OpenFOAM/OpenFOAM...nctionObject.H.
Caelan
clapointe is offline   Reply With Quote
Old   March 11, 2021, 03:46
Default Run time / On the fly Uniformity Index implementation
Balaji
Nealcaffrey is on a distinguished road
Here is a code which you can add in your functions inside controlDict for a user plane or a sampled surface
UniformityIndex_User_Plane1
	    enabled         yes;
	    type            surfaceFieldValue;
	    libs            ("libfieldFunctionObjects.so");
	    writeControl    timeStep;
	    writeInterval   1;
	    log             true;
	    writeFields     false;
	    regionType      sampledSurface;
	    name            User_Plane1 ;
		sampledSurfaceDict
                type        sampledTriSurfaceMesh;
        	surface     User_Plane_P1.stl;
        	source      cells;  // sample cells or boundaryFaces
        	interpolate false;
	    	operation       uniformity; //- options: sum, areaIntegrate
	  //  weightField     phi;
	  //scaleFactor 1.183;
	    fields
		U
Nealcaffrey is offline   Reply With Quote
run-time processing, uniformity index
Fit the image using run time post processing Gaubtas OpenFOAM Post-Processing 2 August 7, 2019 09:38
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
