March 20, 2019, 14:16 |
Point of action of 'forces' functionObject?
Vikram Rajagopalan
Rep Power: 8 |
Can anyone tell me what the point of action of the output of the 'forces' function object is? It provides the X,Y and Z component of pressure, viscous and porous force, but at what point? If I provide only one patch to the function, is it the centroid? Similarly if I proved multiple patches or a group? Can I get the coordinates of this point?
March 21, 2019, 14:58 |
Rep Power: 15 |
General
forces are vectors. vectors does not have an location / point. So, I think you should tell us what you like to do and perhaps you get an answer. |
March 21, 2019, 16:08 |
Vikram Rajagopalan
Rep Power: 8 |
Siassei,
I'm simulating flow over a torpedo (basically a cylinder with tapered edges and two tailfins on one end of it, located 90 degrees apart). I have two patchGroups, one with both fins and another with the body. Surely the point of action of the output of the 'forces' tool will change if I input just the fins vs both body and the fins right? So is this a force that would act at the center of pressure or whatever patches I input? That's what I meant by my earlier question. |
Define Profile, using mass fraction of different point | Kosch | Fluent UDF and Scheme Programming | 0 | October 2, 2017 21:10 |
How to add X and Y forces at a point | cgusty01 | SU2 | 4 | February 18, 2015 14:17 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 12:25 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 23:36 |
FORCES don't run! | C12Carbon | OpenFOAM | 0 | September 10, 2011 08:34 |
