Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Velocity U and Pressure p
Old   January 14, 2019, 17:06
Default Velocity U and Pressure p
Linda Lee is on a distinguished road
Hi all,
I am a beginner of using openFOAM and I use it to simulate the outdoor airflow CFD simulation.
I learnt that the resulting pressure in the simulation is relative. Is the resulting velocity also relative? I have a case that the wind vector generated on three openings (measurement surfaces) of a shelter were all pointing inwards. If the resulting velocity is not relative, the case will not be making sense at all.
Thank you.
Linda
Linda Lee is offline   Reply With Quote
Old   January 16, 2019, 06:37
anonymous
simrego is on a distinguished road
Hi!
First of all the pressure is not always the "real" pressure. Incompressible solvers are using kinematic pressure which is pressure/rho, that's why the dimension of the pressure in incompressible solvers are [m^2/s^2].
If you are using relative or absolute pressure is up to you in incompressible solvers. Only the change of the pressure is important in incompressible solvers (so you can shift the pressure, for example set 0 on outlet instead of 1bar, but again carefully!!! you set pressure/rho in the p file in incompressible solvers!!!), but if you are using compressible solvers, you have to use the absolute pressure since your material properties can depends on the pressure.
Relative velocity to what? Sorry I don't understand exactly what do you mean.
simrego is offline   Reply With Quote
Old   January 19, 2019, 07:05
Hi simrego,
Many thanks for your help.
The velocity I concerned is the result I got from the post-process file (with a file of U and a file of p). The pressure (p) obtained (to my understand) would be the case as you explained. Then, how about the U? Is it the same case (relative or absolute) as p?
Old   January 24, 2019, 09:59
anonymous
Let's say it should be relative to your stationary wall.
Old   January 24, 2019, 14:32
Many thanks.
openfoam, outdoor airflow, velocity and pressure
Initial pressure and transverse velocity fields to initialize turbulence model nickvinn Main CFD Forum 0 February 29, 2012 11:11
Physical meaning of pressure in pressure eqn dontknow Main CFD Forum 2 August 30, 2010 11:12
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 21:04
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
