December 10, 2018, 16:44 |
How to get the resulting velocity?
David
Rep Power: 8 |
Hello together,
after my first simulation with openFoam I wonder how to read the results of the velocity in a useful way. I've already searched a while for the solution but couldn't find a answer I understood. I mean after the simulation openFoam writes the results for every time step to data 'U'. There I get the velocity in x,y and z direction for every cube of my mesh, right? But how do I get the resulting velocity of these 3 directions? Is there a command or a software that one can use to get that output or do I have to calculate it with paraview and if yes, how? Thanks Dave |
December 12, 2018, 08:45 |
Zander Meiring
Rep Power: 8 |
you can make use of paraview. It can display velocities as a magnitude. You can also choose to make use of the glyphs filter in paraview to make use of arrows that represent the velocity vector
December 12, 2018, 09:03 |
David
Rep Power: 8 |
okay, thanks. But I want to get the results as a text file, so that I can compare the velocities. Isn't that possible?
results, velocity |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 12:48 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 07:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
