Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Flat Plate
Old   December 10, 2018, 10:11
Default Flat Plate
Kevin Habrock
Kevin.H is on a distinguished road
Hello, Foamers,
I've been trying to plot the "Law of the wall" on a flat plate for quite some time now. However, I have problems to get the desired values in the turbulent area. I use both a BlockMesh and a mesh from StarCCM to get the result with OpenFOAM (Figure 1.).
StarrCCM: 170042 Cells
BlockMesh V1: 7200 Cells
BlockMesh V2: 220000 Cells
But in all cases I get the same wrong result (Fig2.). I calculated all calculations compressible as well as incompressible.
As reference simulation I use the correct result of StarCCM+ and the literature.
Now the question is whether it may be due to the boundary conditions (Fig3).
I determine the velocity curves and the wall shear stresses with ParaFOAM.
My analytical calculation of the wall shear stress corresponds to the result of ParaFOAM (Fig4).
I would be very grateful if you could take a quick look at my case.
Best regards
Kevin
Kevin.H is offline   Reply With Quote
Compressible Flat Plate with coupled hydrodynamic/thermal boundary layer Obad OpenFOAM Pre-Processing 0 September 14, 2016 15:45
Flow over a flat plate as an immersed solid hamed.majeed CFX 4 September 8, 2016 15:40
Flat Plate Boundary Layer Height kennedy1992 Fidelity CFD 7 February 24, 2016 05:45
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 08:07
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 22:09
