Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Difference between forceCoeffs function and Paraview force calculation
Old   September 28, 2018, 09:33
Default Difference between forceCoeffs function and Paraview force calculation
Aleksei
alexey_sw is on a distinguished road
Good afternoon everyone
I`ve run several cases in rhoSimpleFoam for calculation drag and lift coefficient. Function forceCoeffs was used for run-time post-processing. After I used Paraview to calculate Cl and Cd (only pressure component):
  • Generate surface normals;
  • Calculator => (p)*Normals_X/(0.5*rhoInf*(URef^2)*ARef);
  • Integrate variables.
Results:
forceCoeffs
Cd : 0.0239694 (pressure: 0.0181724 :confused: viscous: 0.00579704)
Cl : 0.260187 (pressure: 0.260349 viscous: -0.000162107)
Paraview
Cd : 0.0408192 :confused:
Cl : 0.257274
My forceCoeffs file:
forceCoeffs1
type forceCoeffs;
libs ("libforces.so");
writeControl timeStep;
timeInterval 2;
log yes;
patches ( "Wall.*" );
// rho rhoInf; // Indicates incompressible
rhoInf 1.225; // Redundant for incompressible
liftDir (0 1 0);
dragDir (-1 0 0);
CofR (-0.44347 0 0); // Axle midpoint on ground
pitchAxis (0 0 1);
magUInf 56;
lRef 0.94; // Wheelbase length
Aref 0.019; // Estimated
binData
nBin 20; // output data into 20 bins
direction (1 0 0); // bin direction
cumulative yes;
Also such differense observed when I run cases in simpleFoam. However, inequality was less then 5%.
Any thoughts? What is the reason of this inconsistency?
I would highly appreciate any advice!
alexey_sw is offline   Reply With Quote
Old   October 1, 2018, 06:20
Aleksei
Problem was solved.
Thanks to this thread https://www.cfd-online.com/Forums/op...-paraview.html I find out that "point" values in paraview are created by interpolation. By changing attribute mode in calculator from "point data" to "cell data" I`ve got Cl and Cd in paraview equal to ones from forceCoeffs function.
Old   June 9, 2021, 05:05
damu
damu1414 is on a distinguished road
Hi Aleksei,
Thanks for the thread. Can you help me calculate viscous drag using ParaView?
damu1414 is offline   Reply With Quote
[OpenFOAM] Probes function gives different values than ParaView Bazinga ParaView 4 November 29, 2017 14:59
[General] Calculation of accumulated drag on bodies in Paraview Jan.Östh ParaView 2 November 3, 2014 05:32
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
[OpenFOAM] parafoam - paraview help function felik9 ParaView 5 June 3, 2010 16:03
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
