Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
nearWallFields error in postProcessing
Old   September 25, 2018, 16:57
Default nearWallFields error in postProcessing
Lorenzo
wilove is on a distinguished road
I'm trying to calculate the UNear field of my simulation but I run always in 2 error.
I execute this command line:
simpleFoam -postProcess -field U -func nearWallFields -latestTime
and I obtain this
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6-1a0c91b3baa8
Exec : simpleFoam -postProcess -field U -func nearWallFields -latestTime
Date : Sep 23 2018
Time : 19:38:13
Host : "lorenzo-SATELLITE-P755"
PID : 21855
I/O : uncollated
Case : /home/lorenzo/OpenFOAM/lorenzo-6/run/Muso0
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 700
SIMPLE: Convergence criteria found
U: tolerance 1e-05
"p.*": tolerance 1e-05
k: tolerance 1e-05
omega: tolerance 1e-05
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 19 the punctuation token '('
file: /home/lorenzo/OpenFOAM/lorenzo-6/run/Muso0/system/nearWallFields.nearWallFields.fields at line 19.
From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
Therefore I remove the brackets from the nearWallFields file, I execute the first command line again and I get the opposite error.
\\/ M anipulation |
Date : Sep 23 2018
Time : 19:41:36
PID : 22463
I/O : uncollated
nProcs : 1
Create time
U: tolerance 1e-05
k: tolerance 1e-05
Expected a '(' while reading Tuple2, found on line 19 the word 'U'
From function Foam::Istream& Foam::Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 92.
If you need to see the nearWallFields file here it is:
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
// Interpolate U to create near-wall UNear
nearWallFields
functionObjectLibs ("libfieldFunctionObjects.so");
type nearWallFields;
writeControl writeTime;
executeControl writeTime;
fields
U UNear
patches (solid_0_Pilota solid_0_Muso solid_0_Monoscocca_DPX_Solida solid_0_FW solid_0_Ant);
distance 0.001;
I really don't know what I'm doing wrong… Any help is really appreciated!
Thank you in advance
wilove is offline   Reply With Quote
Old   February 14, 2019, 05:34
Matteo Pischiutta
matpisk is on a distinguished road
Hi Lorenzo,
did you solve this?
I've the same problem, I'm not able to run nearWallFields in postProcessing.
Thanks
Matteo
matpisk is offline   Reply With Quote
Old   February 26, 2019, 01:19
Lorenzo
Unfortunately I did not.
Old   March 4, 2019, 07:46
Krapf is on a distinguished road
Hi wilove, hi matpisk,
I'm not able to use nearWallFields in post processing, too. Maybe this is not possible? Because if you check
postProcess -list
nearWallFields it doesn't appear in the list.
The only way I managed to get it working, was to add it to the controlDict file and compute it during the simulation.
Kind regards,
Krapf
Krapf is offline   Reply With Quote
Old   April 11, 2019, 04:37
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Guys,
Lorenzo, I'm not sure whether your tried it or not, but my best bet is that your nearWallFields function object misses two brackets.
It should be written this way :
fields
    (U UNear)
Generally speaking, this is a good habit to refer to the headers in the source code to get information and usage examples.
Here you get everything you need from the $FOAM_SRC/functionObjects/field/nearWallFields/nearWallFields.H :
 Description
    Samples near-patch volume fields.
    Fields are stored
    - every time step the field is updated with new values
    - at output it writes the fields
    This functionObject can either be used
    - to calculate a new field as a  post-processing step or
    - since the fields are registered, used in another functionObject
    Example of function object specification:
    \verbatim
    nearWallFields1
        libs        ("libfieldFunctionObjects.so");
        fields
            (p pNear)
            (U UNear)
        patches     (movingWall);
        distance    0.13;
    \endverbatim
Usage
    \table
        Property | Description               | Required    | Default value
        type     | type name: nearWallFields | yes         |
        fields   | list of fields with correspoding output field names | yes |
        patches  | list of patches to sample | yes         |
        distance | distance from patch to sample | yes     |
    \endtable
Let us know if it solves your problem.
Yann
Yann is offline   Reply With Quote
error, nearwallfields, openfoam, postprocessing, simplefoam
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 10:55
How to export the specific heat and viscosity for postprocessing (compressible) ? david39 OpenFOAM Post-Processing 2 January 4, 2019 08:04
Postprocessing in 3d - Creating part of a surface shankara.2 FLUENT 0 July 13, 2009 18:33
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 17:17
postprocessing bas rijkse FLUENT 0 July 5, 2001 09:30
